SAY IT AIN"T SO!
SAY IT AIN"T SO!
Well, I just got done installing my crate motor 350 into my 89 IROC. Everything is done so i figure its a good time to install a starter. THE FLY WHEEL IS TO BIG! I tried both types of chevy starters but the nose won't fit between the fly wheel and the bellhouseing. Its a 168 Tooth flywheel i imagine. I thought it should work tho? Give me your input, thanks.
Matt
Matt
Car: 4
Engine: 6
Transmission: 5
Car: RS
Axle/Gears: 9" for the ladies
Yep I had the same problem. Summit sells one that will work for $175!! I looked all over parts stores for one that would work but no luck.
Car: 4
Engine: 6
Transmission: 5
You probably can't use the old one, but maybe you can. If your new engine has the one-piece rear main seal, then you can. If not, you'll have to buy another one. About $40 or so at Auto Zone or some such. No big deal at all.
To change it, take all the trans bell housing bolts out axcept for the 2nd one on each side; put a long (~6") bolt in the bottom one on each side; that way you can slide the trans back as far as it can go on a jack or something, without having to take it completely out. That gives you plenty of room to get to the flex plate bolts with a box-end wrench.
ICON Motorsports
ICON Motorsports
Or go and get the mini-starter from... errr... TommyJonesJr.com or something like that... Damn - total brain dump. If no one else knows what I'm talking about and you still want the information email me at scauffiel1@home.com and I'll dig up the info. It cost around $150 and got here in three days. Lemme know,
Darth Steve
Darth Steve
Car: 1989 TTA #1240
Engine: 3.8 SFI turbo
Transmission: 2004r
just get a starter for a 4th gen camaro 6speed it has a smaller nose cone on it should fit no problem
87 trans am 350 L98 aluminum heads,LT4 hot cam,slp runners,1 5/8 headers,y-pipe,edelbrock base,hi flo cat,air foil,afpr,ported plenum,t-5 tranny w/centerforce clutch and a 3.27 9bolt(11.9in. brakes),ads strip chip,relocated iat sensor,hollowed maf
14.10@97mph w/2.01 60'
superram and chip coming soon
<font face="Verdana, Arial" size="2">Originally posted by PETE:
</font>
</font>
Matt
No luck yet. We dropped the trans to get to the flywheel and pulled it off. The motor we are swapping has the 2 piece rear main. The origional flywheel that came with the motor was actually scraping the bellhouseing when it turned. So now i'm looking for a flywheel that will fit with no luck. The only one i can find is made by B&M and will cost me a small fortune. If anyone knows of a flywheel that will fit a 700R4 with an old style motor then can you please let me know? Thanks
Matt
Matt
Transmission: 4L80E/4L80E
Get one for an '83-'85 Camaro/FB 305.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4. 2.93 limited slip. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/'87 LB9 block, ZZ3 cam and intake, World 305 heads, Hooker headers & y-pipe, 3" Catco cat & 3" cat-back).
57 Bel Air, my 1st car. '66 396, 9.7 CR forged TRWs, Weiand Action+, Edelbrock 1901 Q-Jet, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 600 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
