What needs done so I can use a 2peice rear seal block?
Old Jul 11, 2001 | 01:24 PM
leirch's Avatar
Guys,
I posted about this in another thread, I found a 69block 4bolt main 350, all numbers match. It has the crank and thats it. What would I need to do to use it with EVERYTHING from my current setup?
Thanks,
Brendan
1987 IROC-Z L98,SR,EB 6085's,LPE 219/219 SR Cam, Crane 1.6RR, EB TPI Base, 58mm TB, ADS 24#, AFPR, K&N, EB TES, Catco Cat, 3" Borla Cat-Back, Accel cap,rotor,distro/other crap, Aluminum DS, 94 Disk Rear, Adjustable Prop Valve, Precision 3.73 Gears, Weld in Sub-Frame Connectors, Hotchkis LCA's, KYB Shocks/Struts, Poly Bushings all over the place, Moog Upper/Lower Ball joints and Tie Rods ends/Idler Arm, Big stereo, 730SD Conversion.
To see the ROC, Check out the webpage Here
Old Jul 11, 2001 | 04:23 PM
MRZ28HO's Avatar
Car: was: 1984 Camaro Z28
Engine: was: L69
Transmission: was: 700-R4
Long or short block?
If short block, all you need is an internally balanced damper of 6.75" diameter. All else will bolt up. Plus you will need a fuel pump block off plate.
If long block (above applies as well), you will need to elongate the center two pairs of intake bolt holes for the intake manifold.
George P. Lara
1984 Z28
2001 SS #0391
SCCA, SCFB, SC3GFB
[This message has been edited by MRZ28HO (edited July 11, 2001).]
Old Jul 11, 2001 | 06:25 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Doesn't he have to get a different flexplate/flywheel (depending on trans) due to the different bolt pattern on the two types of cranks?
Old Jul 11, 2001 | 09:11 PM
Guest
Guest
Posts: n/a
Yea, if he has an auto (assuming he does) he needs to order a flexplate for the earlier block... no biggie.
Old Jul 11, 2001 | 09:29 PM
leirch's Avatar
Oops, forgot to mention that I have a T5. So basically I should be able to use my lifters/rollercam/heads/etc...
The only difference when doing the 1peice to 2piece comparison is the Flexplate??
If so I think I'm going to get that block.
Brendan
Old Jul 11, 2001 | 10:26 PM
Guest
Guest
Posts: n/a
Heads, yes. Lifters and rollercam... Um no, you will unfortunately not be able to use those in that block. You may be able to swing using the cam and have to buy just lifters, but I havent yet verified if the older style timing chain will bolt up and work without problems.
Sorry I missed that part earlier.
So to make it complete:
As is, the cam, lifters, timing chain, crank, and flywheel off of your current setup will not work on that engine. The pistons may or may not work, depending on overbore issues. The rods will work. I think that about covers it.
Old Jul 11, 2001 | 10:54 PM
leirch's Avatar
Ok, so basically thats way more time than I want to waste. No wait, let me rephrase, not time wasted but money that I don't have..
I think i'm going to search for a 87+ roller block.
Thanks to all for the help,
Brendan
1992 Trans Am
May 10, 2023 07:19 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Reborn756
Sep 4, 2015 03:42 AM
86White_T/A305
Aug 17, 2015 12:16 AM
Exxon Limited
Aug 9, 2015 08:13 PM
