Running TPI on a 400?
Old Jul 14, 2001 | 05:00 PM
mongse_1's Avatar
Car: '95 TT Trans Am
Engine: 383 LT1
Transmission: TH400
Is it possible to run the TPI setup from a 350(or 305) on a 400 small block? Personally, I think that a DFI system or Mini-Ram would work the best, but I'd like to explore the stock TPI & runners before I move into the big $$$ stuff.
Crazy Joe says:
"No matter what kinds of sounds you hear from under the hood, the motor's never been cracked open! I swear!"
Old Jul 18, 2001 | 07:28 PM
aziroc's Avatar
Car: 86 IROC-Z
Engine: 406
honestly .. dont believe that miniram stuff *unless u want to go over 6500 rpms* im doing a 406 project *trying for 500 HP* and i found better numbers going with a modified TPI set-up vs the superram or mini ram. by modified i mean a big mouth intake *tpis* large tube runners *tpis* and 58mm T.B. *so far i found BBK to be the cheapest and best*
the reason for the tpis big mouth vs an edelbrock is because there is alot more to post on the bigmouth then the edelbrock. plus the flow #'s *if u did not port the intake* are better on the big mouth. but as far as just swaping your tpi unit over to a 400 block.. u will starve the engine if u dont do the following stuff. plain and simple
Old Jul 18, 2001 | 09:02 PM
Tas's Avatar
Tas
http://members.tripod.com/GRK_Taz/efi.html
-Tas
'89 Formula WS-6
305, TBI, auto, 14x3 chrome flat based open element with K&N, Milodon 160* thermo, functional Formula hood, cross-flow Flowmaster, '99z28 rear pipes and tips....
To be installed eventually far far far into the future: Yours if the price is right and I don't have to ship :
Hooker 1-5/8" 50 state legal headers, Dynomax 3" I pipe (PN 44063 and 43248), Catco 3" cat, and injector spacer.
Super GRK_Taz World
F-Body Dual Exaust
EFI & Intake Options
AOL IM: superGRtaz
camaro71633
Sep 1, 2015 10:24 AM
lakeffect2
Aug 23, 2015 08:44 AM
Sanjay
Aug 12, 2015 03:41 PM
Bradsaundry
Aug 12, 2015 12:34 AM
squiggy2
Aug 9, 2015 09:30 PM
