are these the right heads??
Old Jul 18, 2001 | 07:23 PM
aziroc's Avatar
Car: 86 IROC-Z
Engine: 406
ok.. well as time ticks down to the lift-off of my 406 project i am beginning to shop around more and more. *notice the BBK T.B. post* and i want to try to make about 500 hp out of it. i am looking @ AFR 210 heads. would that be good/overkill or should i go with 195's? thankfully CHP did an artile on different engine combos. and 1 of them was a 485hp 406. im thinking about just copying it except im putting TPI on there. *big mouth, larger runners, 58mm T.b. ect...ect...* the reason i dont want the miniram is because it*mini ram* doesnt get its power till after 6500 rpms and i dont plan on reving a 406 past 6000. most of it's *the 406* power is around the 5000-5500 rpm range. any other inputs?
Old Jul 18, 2001 | 09:05 PM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
Either head you get you will need to have them hand-ported. For the money, the TFS 23* heads are cheaper, and then with a good port/polish around $650 you can match the AFR price and beat the AFR's in airflow. The competition package porting on the AFR's from them is not cost effective. I think the 210 heads need to be port matched to the intake in order to get the correct fit/angle. You might want to call AFR to verify.
You can get the power you want with ported Trick flows or ported AFR 190-195's.
Get your lower intake hand ported also, and get the lower and runners extrude honed for more flow. The intake is the most restrictive part of the tpi system.
Old Jul 19, 2001 | 12:05 AM
aziroc's Avatar
Car: 86 IROC-Z
Engine: 406
lol.opps i should have included that everything is getting ported/polished. actually hes doing it for free.. 1 because i told him where his friend can get a 79 T/A 6.6 for $1000 in perfect condition and 2 becuase im taking my car in *with 10k* for them to play with. but yes.. everything is getting ported. now what about exuast?? SLP's 1 3/4" headers..into what muffler??Borla XR-1, Flowmaster 30-40 series, SLP loud mouth???
Hotrodboba400
Dec 10, 2019 07:07 PM
92projectcamaro
Jan 18, 2016 08:00 AM
FormulasOnly
Sep 6, 2015 10:42 AM
z28guy134
Sep 1, 2015 11:50 PM
