old school or new school 383?
Old Jan 7, 2010 | 11:36 AM
jak2908's Avatar
Car: 89 RS,89 iroc
Engine: 5.0,5.0tpi
Transmission: 700R4,700R4
Axle/Gears: LSD,LSD
what do people have out there? what is preferred? what are the pros and cons of each? thanks!
Old Jan 7, 2010 | 11:41 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: old school or new school 383?
What are you calling "old" and "new"?
Old Jan 7, 2010 | 11:43 AM
3rdgenmaro's Avatar
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
If you are talking
old= 400 crank and rods into a 350
new= 383 specific new crank and rods
then definately go new. The old style used very short rods. They dont hold up as well.
Old Jan 7, 2010 | 06:35 PM
jak2908's Avatar
Car: 89 RS,89 iroc
Engine: 5.0,5.0tpi
Axle/Gears: LSD,LSD
ya thats exactly what im talkin about
Old Jan 7, 2010 | 06:59 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
When I bought my car, it had a high mileage old school 383 in it. Cast 400 crank. 400 rods and rod bolts, cast 350 pistons. It had a nice solid cam but poor smog heads. The first year I raced it, I managed a best of 14.0. After the first season, I yanked off the heads and put some big valve, highly ported camel heads on the engine and swapped out the 700R4 for a TH350 with a 3800 stall converter. First pass of the second season, I ran 12.0 and everyone wanted to know where I hid the NOS bottle. I managed a very high 11 by the end of the season and on the last race day of the second season, the engine let go. I don't know if a rod bolt failed or a piston disintegrated. I yanked the intake and heads off and threw the rest in the scrap metal. The heads had 5 visibly bent valves to give you an idea on how much damage was done.
I managed 200 1/4 mile passes with the engine and know the engine was in at least 3 other cars before being put into the Camaro. It's hard to know exactly what failed but I was also spinning it to 7000 rpm and near the end of the second season, I was using a 2-step.
A "new school" 383 with better parts would probably have survived a lot longer but would also have cost a lot more to build. If you do manage to find a 400 engine to use the crank and rods to make a 383, it would be much better to just build the 400. For a typical street car with limited or no track time, there's nothing wrong with building an old school 383 for nothing more than some machine shop work. The mains on the 400 crank need to be turned down to fit in the 350 block then the block needs to be bored .030" over. Oversize cast pistons are cheap. If the 350 has already been bored out, it's just a matter of changing the crank and rods.
Old Jan 7, 2010 | 07:17 PM
jak2908's Avatar
Car: 89 RS,89 iroc
Engine: 5.0,5.0tpi
Axle/Gears: LSD,LSD
that sounds pretty good..i'd like to atleast run 6500 with it..what were you using for a cam? and would some vortec heads be decent?
Old Jan 7, 2010 | 07:37 PM
LilJayV10's Avatar
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Transmission: TH700R4 w/2800 stall
Axle/Gears: 3.23 Posi
The vortec heads would work but are going to limit your airflow. I think they are around 170cc. It just depends on how high you are going to spin and how big of cam you have.
Old Jan 7, 2010 | 09:23 PM
AlkyIROC's Avatar
Car: 87 IROC L98
I can't remember the exact cam. Could have been Crane or CC. It was a solid flat tappet with around .550 lift. I can't remember any more specs since that was almost 10 years ago. The cam number might still be on my car's web page.
Old Jan 7, 2010 | 10:49 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Originally Posted by 3rdgenmaro
If you are talking
Sounds old-school to me.
New school would be a stroked LS1.
LT1Formula
Oct 8, 2015 08:34 PM
92projectcamaro
Sep 29, 2015 07:07 PM
