V6 to V8 wiring question
Old Jul 19, 2001 | 12:26 AM
LilJayV10's Avatar
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Transmission: TH700R4 w/2800 stall
Axle/Gears: 3.23 Posi
I am in the process of emlinating the wires from my V6 harness that i dont need. i labeled the ones that i knew, oil pressure, temp, stuff like that. what else do i need? i know there has to be important relays that i need, fuel pump, stuff like that. any help would be great. thanks.
Wide Open Till You See God...Then Brake
Old Jul 19, 2001 | 07:12 AM
multi-tasking's Avatar
I could use some help in this area also.
Old Jul 19, 2001 | 02:59 PM
Big Money Mike's Avatar
Im swaping out a 2.8 MPFI for a LG4 305. When I bought the motor, it came with absolutley everything. It has 2 wiring harnesses. 1 that plugs up to the headlights, turn signals and all that stuff, and the second hooks to the engine and runs to the computer. I was wondering if I could leave the V6 harness connected to the lights and stuff, and use it in conjunction with the 305 engine and computer harness. So far, Ive compared the V6 lights and accesories harness to the same one for the V8 and they appear to be the same.
PS- Anyone have a V8 T5 bellhousing they want to sell me cheap?
Mike D.
[This message has been edited by Big Money Mike (edited July 19, 2001).]
Old Jul 19, 2001 | 05:56 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
If you aren't doing computer controls, you need the wires for distributor power, tach, alternator, starter, choke, oil pressure gage, temp gage, AC, wiper motor & washer, and possibly radiator fan, fuel pump (if you have electric and are keeping it) and fast idle solenoid. Some of these will be too short (like those at the front of the engine). You might be better off going to a junk yard and getting the engine harness from a V8 car, especially if you're staying CC.
I started switching out the light harness, finally figured out I didn't need to. I did have to change out the cruise harness, but that's because I basically took my '82 V6 car and made it look like the '86 V8 car under the hood and dash.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4. 2.93 limited slip. Cat-back from '91 GTA, ZZ3 intake, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/'87 LB9 block, ZZ3 cam, ported World 305 heads, Hooker headers & y-pipe, 3" Catco cat & 3" cat-back).
57 Bel Air, my 1st car. '66 396, 9.7 CR forged TRWs, Weiand Action+, Edelbrock 1901 Q-Jet, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 600 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
Old Jul 19, 2001 | 06:16 PM
LilJayV10 thats a good question... Are you going carb, TBI or TPI? I am going TPI. Do you have a complete harness or a partial one? I have a partial harness..computer control only. I made my fuse block harness.
five7kid why did you have to change you cruise harness? You were like my hero until you said that!
v/r guys
m-t
Old Jul 20, 2001 | 03:45 PM
five7kid's Avatar
The '82 had an old govenor-type unit on it, the '86 uses the ECM. Everything was different from the cables, hoses, wires, servo, button on the turn signal arm - everything. That's why. Nothing to do with V6 to V8, just the year differences.
Old Jul 20, 2001 | 04:39 PM
Oh, OK you can still be my hero
Cleotiz
Jan 6, 2018 08:56 PM
Caspar
Jun 19, 2016 11:19 PM
Bryan F
Aug 18, 2015 02:28 PM
86IROC112
Aug 17, 2015 07:57 PM
redmaroz
Aug 16, 2015 11:40 PM
