pros and cons with using 305 heads on 350
What are the good and bad points?I might do it for the good low end torque and mainly cuz im on a budget and their free so....
1985 Firechicken
2.8 v6
Mods:
TB Coolant Bypass
My own kik @$$ dual intake
Freshly Painted(bright metallic blue)
Mods to come:
Either an 80 series flows or super turbo dynomax.Cant decide!
An engine is like a person,to scream it has to exhale hard -Flowmaster
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Pros:
They're everywhere.
They can raise compression up to over the limits of pump gas
Cons:
Just like every other casting you need to know which ones are prone to cracking.
The combustion chamber is so small that larger valves for the bigger cubic inches are out of the quetion.
They don't flow enough air to adequately feed a larger engine.
None of ther 305 heads are considered performance heads.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z SuperPro ET Bracket Race Car
461 naturally aspirated Big Block
Best ET on a time slip: 11.242 altitude corrected to 10.89
Best MPH on a time slip: 121.52 altitude corrected to 125.89
Altitude corrected rear wheel HP: 497.9
Best 60 foot: 1.546
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
They're everywhere.
Cons:
Best 60 foot: 1.546
