Old 350 in a 91 rs?
Car: 88 Sportcoupe camaro
Engine: forged 355
Transmission: th350
Old 350 in a 91 rs?
I fineally got another 3rd gen (91 rs,tbi 305,5spd) I am taking the motor out of my 85 c10 that I just got done building. The motor is a rebuilt 1st gen 350 with double hump heads/voodoo cam/780 carb. Is a fpr all I need to use the carbed 350 or will I run into other troubles since the car is computer controlled?
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Old 350 in a 91 rs?
You're issues might be with accessories - if those heads have accessory holes in them to mount alt, p/s pump, etc. then you'll be fine - if not then might have to get old school accessories and brackets that mount to block rather than heads. I'm assuming this will be carburated, so yes you'll need a return-style fpr like the Mallory 4309. Also need a vacuum advance dist., and a method for locking up the torque converter if using the 700R4 auto transmission.
Read the carb swap sticky in the carb forum.
FormulasOnly
Sep 10, 2015 09:07 PM
