Lemons Tri-Y big block header update
Old Aug 1, 2001 | 03:46 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Refer to https://www.thirdgen.org/messgboard/...ML/001363.html
Old Aug 12, 2001 | 11:09 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
I ask about using them on tall deck blocks and this is what I got for an answer.
Our '82-'92 for BB & SB have been in production now for a few months and are working out great. Like our other headers we make each one to order so if you have a tall deck and raised port heads we add those diamentions to the header so it fits properly. The BB header fits the factory frame and "K" member, it has 2 tubes on the passenger side and 1 tube on the drivers side that go around the frame. Has good ground clearance, spark plug, oil pan and starter clearance. The tightest area is around the transmission and collectors because of the shape of the floor board. Comes with slip on merged type collectors, with a transition cone inside, 3/8" flanges, TIG welded etc. They cost $850.00 for any tube size up to 2 1/2" with step or non step design.
Thanks again, Dan Lemons
I guess going around the frame and crossmember solves the clearance problem the the Hookers have. Can't fit all the tubes through a tiny opening, route them somewhere else.
Although I never got a chance to look under the hood I saw some interesting headers on a dodge stock eliminator car today. The exhaust exited in front of the front wheels. Not enough room to go backwards, go forwards.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z SuperPro ET Bracket Race Car
461 naturally aspirated Big Block
Best ET on a time slip: 11.242 altitude corrected to 10.89
Best MPH on a time slip: 121.52 altitude corrected to 125.89
Altitude corrected rear wheel HP: 497.9
Best 60 foot: 1.546
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Old Aug 13, 2001 | 01:08 AM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
The headers they are making for me are a custom job and not a catalog item. You will need to remind Dan that you are interested in the Tri-Y design he is currently fabbing for Jon and his big block '89 Firebird.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
evilstuie
Feb 28, 2016 03:33 PM
gixxer92
Sep 1, 2015 04:32 PM
BlackphantomZ28
Aug 22, 2015 01:00 PM
sreZ28
Aug 14, 2015 07:48 PM
