Complete new shortblock or get stock block bored and put in a 383 rotating assembly?
Old Aug 11, 2001 | 09:24 PM
BuckeyeROC's Avatar
Car: 2015 Camaro Z/28 & 2013 Super Bee
Engine: LS7 and 392 HEMI
What would be a cheaper and /or better way to go: Buy a new 383 shortblock or take the stock 350 block to a machine shop and buy a 383 rotating assembly? Also, what would the machine shop charge for all that needs to be done to the stock block?
Old Aug 12, 2001 | 07:53 AM
ede's Avatar
ede
considering all the grinding you have to do to make the rod bolts clear i'd look at buying a assembled short block. make sure you use rods with bolts and not the bolt/nut type, you'll gain a little more clearance that way. like anything else it comes down to what you can afford and how much time you have.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Aug 13, 2001 | 11:01 AM
Scott 87 IROC-Z's Avatar
Car: 87 IROC-Z28
Engine: 377ci, Brodix Heads, Solid Roller c
Transmission: 700-R4 w/ Yank ST3500 Converter
The machine shop only charged $80 to clearance the block for the 383. Other than that, there was no additiional charges for the 383 than if I had gotten a 355.
87 IROC-Z 305 TPI gears, exhaust, converter
14.70 at 94.1 mph
Solid Roller Minirammed 377 - It's Alive !!!
Terrell351
Jun 13, 2021 01:13 PM
9192camaro
16
Feb 3, 2019 12:21 AM
Casey Meyers
Mar 2, 2016 10:46 AM
Reddeath210
Oct 6, 2015 08:20 AM
camaro71633
Sep 1, 2015 10:24 AM
