Flexplate- is this a problem??
Old Aug 4, 2001 | 11:48 AM
Damon's Avatar
Just bolted a 1975-vintage 400 in my brother's 87 GTA originally equipped with the L-98 350 and 700R4 auto-box.
Car still has the original torque converter in the trans. My original 1975 400 flexplate bolts right up since it's drilled for both the large and small pattern torque converter (the 700R4 converter usues the small bolt pattern). All is going well UNTIL.......
I go to tighten down the flexplate-to-torque converter bolts. They go in just fine but the torque converter and the flexplate have about 1/4" of space between them. naturally, as I tighten them down the torque converter pops forward that 1/4 inch. YES, I have the flexplate on the right way around.
Is this going to be a problem? How far forward can the converter go before it disengages from the front pump and/or loses it's seal to the rest of the trans?
All other swaps I have done the convter and the flexplate are just about touching eachother even before the bolts go in. The L-98's once piece-style rear seal crank must put the flexplate just a smidge further back than an older style Small Block is my guess.
Problem???
[This message has been edited by Damon (edited August 04, 2001).]
Old Aug 5, 2001 | 11:21 AM
james_fearn's Avatar
wrong post
[This message has been edited by james_fearn (edited August 05, 2001).]
Old Aug 9, 2001 | 11:50 AM
82suped-up-coupe's Avatar
new to me
I'd definately find out for sure before I buttoned it up though
Old Aug 9, 2001 | 06:23 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I'd suggest giving Dana at Probuilt a call.
Old Aug 10, 2001 | 02:18 AM
JoelOl75's Avatar
Car: 88 Firebird WS6
I usually see 3/16" of gap to close. I'm not sure what the max is.
Old Aug 13, 2001 | 07:58 PM
406TPI's Avatar
Car: 1985 IROC-Z
Engine: Magnacharged LS1
Axle/Gears: Ford 9" 4:11's
.250 is fine for a gap...not a problem!
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
greenyone
Sep 2, 2015 03:39 PM
