What will it take to put my camaro motor into my TA
Old Aug 10, 2001 | 02:11 PM
Wasted420's Avatar
I have an 84 Z28 with a L69 motor in it. I want to put it into my 91 TA. Will the motor drop right in, or will i need a special adapters to get it to work. Also will the TPI system that is on my TA motor fit right on the camaro motor. Thanks
Old Aug 10, 2001 | 02:33 PM
Guest
Guest
Posts: n/a
They are both Chevy engines, no problems cept the 91 intake has the 4 center intake bolts at a slightly different angle than the 84, you will have to slightly modify the bolt holes to get it to work.
Old Aug 16, 2001 | 12:39 AM
Keith5's Avatar
Car: C1500
And the 91's flexplate/flywheel won't work on the '84. Just use the '84's stuff where is needed and it should work except for those intake bolts.
jhawkeye
May 25, 2022 06:33 PM
Mutillator
Exterior Parts for Sale
Jan 2, 2016 06:44 PM
BlackphantomZ28
Aug 31, 2015 10:29 AM
slade5612
Aug 11, 2015 07:19 PM
Leggman1
Aug 6, 2015 04:15 AM
