Attn: Guys with 305 strokers
Old Aug 16, 2001 | 07:42 AM
BJK85Z28's Avatar
From: a tiny cardboard box located at your local garbage dump
How many guys here have stroked 305's? What does that bring the cubic inches up to? What is the fuel mpg difference between the stroked 305 and the stroked 350? I'm considering stroking out my 305 but am not ruling out a 350. I would want the 350 more if it wasn't the "popular" swap to make...
Old Aug 16, 2001 | 09:02 PM
berts's Avatar
well you know this better than anyone else the 305 and the 350 are the bad guys in the chevy small block cuzz for what they are w/ no real power. I just did a 305 w/ a 350 crank (I shelled out some money.) I had to get it remilled, diff. cam you name it. It was a pain in the butt. but for power and cubes "sounds like a big block, but runs like a 327" for the hp I think I'm only getting about the mid 200s. the power band is around 3000 to 5500 RPm. You DO NEED A STALL CONV. or a stick. I can tell you this It will peg the tach! and still hold together. good luck and get your wallet ready..
Old Aug 16, 2001 | 09:18 PM
jamesbern's Avatar
Stroking a 305 brings it up to 334 or more depending on the bore size. Gas milage 334 was about 23-25 in my car, 383 20-22.
Old Aug 16, 2001 | 09:56 PM
87RS402's Avatar
<font face="Verdana, Arial" size="2">Originally posted by berts:
. I just did a 305 w/ a 350 crank (I shelled out some money.) I had to get it remilled, diff. cam you name it. It was a pain in the butt. but for power and cubes "sounds like a big block, but runs like a 327" ..</font>
THe 350 and 305 cranks are the same.... Are you sure you don't mean a 400 crank?
Old Aug 17, 2001 | 01:41 AM
Blue_Meanie86SC's Avatar
<font face="Verdana, Arial" size="2">Originally posted by jamesbern:
Stroking a 305 brings it up to 334 or more depending on the bore size. Gas milage 334 was about 23-25 in my car, 383 20-22. </font>
Is yours carbed or a fuelie? I'm looking at either a 334, 350 or 383. Also, what kind of hp do you get?
1986 Camaro Sport Coupe
Stock 305 cid. LG4 engine
3" catback dual exit exhaust
Metallic Indigo Blue Paint
Gloss Black Interior
L69 dual snorkle intake
Old Aug 17, 2001 | 10:23 AM
BJK85Z28's Avatar
What would the cubic inches be if you bored the block .060"-over? Can you even bore a 305 that far?
Also, jamesbern, what gear were you running in the rear? That would have an impact on gas mileage.
[This message has been edited by BJK85Z28 (edited August 17, 2001).]
Old Aug 17, 2001 | 08:40 PM
berts's Avatar
to reply to "87RS402" it was from summit Lunati racer series crakshaft (main 350 small block, stroke 3.750 , pine 2.100 and rod @ 6.0 4340 steel forge it was about 1,100 bucks and the chamfered bearings were around 50. If that's was they use in a 400 I think I'll blow a freake'n nut! by the way it came in a nice box...
Old Aug 18, 2001 | 11:52 AM
jamesbern's Avatar
2.73's
Old Aug 18, 2001 | 02:28 PM
87RS402's Avatar
Lunati racer series crakshaft (main 350 small block, stroke 3.750 , pine 2.100 and rod @ 6.0 4340 steel forge it was about 1,100 bucks and the chamfered bearings were around 50. If that's was they use in a 400 I think I'll blow a freake'n nut! by the way it came in a nice box...</font>
Get a towel... What you have there is a high-end 400Sbc aftermarket crank. Take that same crank and put it into a 350 +.030" and you have a 383. It is a nice piece though...
Old Aug 20, 2001 | 07:01 PM
berts's Avatar
dude I'm limp'n now, Your right, I checked it out. Man that was good salesmen. I will reuse it in a 350ci. after getting it reworked and poss. stress-test'd. but for now let's see if it will twist...lol
jhawkeye
May 25, 2022 06:33 PM
Jake_92RS
Jan 28, 2020 10:37 PM
mhatfield 14
Oct 24, 2015 07:48 AM
Street Lethal
Aug 14, 2015 08:25 PM
