383 rotating assembly in a 305?
From: a tiny cardboard box located at your local garbage dump
Would the Eagle 383 rotating assemblies from Jeg's fit in a 305 block (bored .030-over, of course)? I've heard people talk about Powerhouse Products having the only 334 stroker kit available but shouldn't this kit work if you used 305 pistons?
1985 Chevrolet Camaro Z28 Sport Coupe
LG4 305ci
700-R4 auto
LG4 305ci
700-R4 auto
Transmission: 4L80E/4L80E
A 383 rotating assembly with 305-like pistons IS a 334 stroker kit. I say "305-like" because you can't just put regular 305 or 350 pistons in with a stroker crank.
To expound: 383 stroker kits use 4.030" diameter pistons. 334 stroker kits use 3.766" diameter pistons. Both use a 3.75" stroke crank vs. the stock 3.48" stroke for 305/350's. The wrist pin for stroker pistons is located 0.135" higher (half the stroke difference) relative to the piston crown than .030"-over 350 or 305 pistons, respectively, due to the longer stroke.
And, no, you can't bore a 305 block out to 4.030".
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4. 2.93 limited slip. Cat-back from '91 GTA, ZZ3 intake, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/'87 LB9 block, ZZ3 cam, ported World 305 heads, Hooker headers & y-pipe, 3" Catco cat & 3" cat-back, Spohn SFCs).
57 Bel Air, my 1st car. '66 396, 9.7 CR forged TRWs, Weiand Action+, Edelbrock 1901 Q-Jet (Holley 3310 on the way), GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 600 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
1992 Trans Am
May 10, 2023 07:19 PM
Fast355
Dec 2, 2016 06:33 PM
ambainb
Apr 25, 2016 09:21 PM
mhatfield 14
Oct 24, 2015 07:48 AM
gixxer92
Sep 1, 2015 04:32 PM
