BBC & Tall valve covers & Wiper Motor Solution
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
I think I have the solution to the interference of a big block with tall valve covers (roller rockers) and the wiper motor. I was in the yard recently looking for parts and found a wiper motor in an iroc that looked different from the 2 speed or the delay version. So I grabbed it, brought it home and sure enough, it is smaller than the GM versions. It is an aftermarket wiper motor (not sure from which parts store).
I am going to install (or atleast try) this weekend.
Miles
88 427 Camaro
12.18 @ 113mph 1.75 60ft
Currently installing 3.73's into my 9 bolt (YES, it is a 9 bolt & YES they are 3.73's, not 3.70. I currently have 4.10 gear sets and new series 3 carriers in stock for 9 bolts
www.koolmeister.com
Miles
88 427 Camaro
)www.koolmeister.com
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Some offshore replacement motor maybe? I'm glad I don't have those clearance problems
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
Actually, it says "made in mexico". I don't care where it was made, just so it works! as I do have those problems
Did you get your motor back together yet?
Miles
88 427 Camaro
www.koolmeister.com
.Did you get your motor back together yet?
Miles
88 427 Camaro
Car: 87 IROC L98
It's "supposed" to be ready tomorrow (friday 24). I'll still have to finish assembling it since it's just a long block. I won't make Sunday's race but should make it to the seasons finals in 2 weeks. Then the season is over until next May. I want to at least get a base line of how the new engine runs so I'll know how much of an improvement I'll get next year.
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
Good luck. Always nice to make the last race of the year.
88 427 Camaro
www.koolmeister.com
88 427 Camaro
Car: 87 IROC L98
The machine shop recieved the wrong rings. Everything else is done except they can't assemble it without rings. I should get the engine now on Tuesday or Wednesday depending on when the rings arrive.
I'm still using the xtreme energy 294 cam. The engine builder says I should just go to a solid cam. He's going to check to see what the maximum lift I can go to with the new heads and pistons. If I can put a .650-.700 lift cam in it, I'll consider picking one up. Flat tappet is cheap but I've been watching on ebay for a roller cam and lifters.
He figures with my current setup and the new Merlin heads, I should be able to get into the 10's. I think I'll need more converter. An 8 inch that stalls around 4500.
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
I run a solid lifter cam. Much better than a hydraulic, but nothing like a roller
The advantage for me was a solid gives more lift for the same duration as a hydraulic. I check clearances in the spring and summer. Never had a problem. Keeping the duration relatively short helps keep it streetable. Then again, so does 9:1 compression and 87 octane (which is $1.70 here!!) Yeah, like Bush and Cheney are going to do anything about that! Bunch of rich oil men
Opps, sorry 'bout that.
Miles
88 427 Camaro
www.koolmeister.com
Opps, sorry 'bout that.Miles
88 427 Camaro
NBrehm
Aug 25, 2015 11:49 PM
