What kind of chips?
Old Aug 26, 2001 | 12:40 AM
jijiandfarmgang's Avatar
What kind of chips?
Hi,
I was wondering what kind of chips you guys were using after swapping from 305 to 350. Is anyone getting away with just performance ones or are you using custom chips thanks.
Old Aug 26, 2001 | 01:16 PM
Damon's Avatar
Any time you add alsmot 50 cubic inches to a motor a custom chip will help quite a bit. Sotck programming was never designed to deal with those kind of drastic airflow chages.
However, you can run a MAF style FI system with the stock chip. The MAF allows the ECM to directly read how much air is going into the motor and compensate for it, even with a slightly hotter cam.
A speed density type FI system (91-92) will run acceptably with a stock chip as long as you use the larger 22# injecotrs from a 350 TPI motor when you do thw swap. This assumes a fairly mild stock-type cam in the new 350. Any change to a hotter cam will drive the speed density programming bonkers, bigger injectors or not.
Linson
Oct 24, 2025 02:00 PM
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Gunner242
Dec 25, 2015 04:49 PM
KO1
16
Oct 15, 2015 05:00 PM
jaridjohn
Oct 5, 2015 07:01 AM
