WHITE SMOKE!!
Old Aug 27, 2001 | 10:28 PM
Polivick'sRS's Avatar
WHITE SMOKE!!
I have a 92 Camaro RS and Im pretty sure I have a blowen Head Gasket Now here is the dialema Its only a 305 and I really want a 350 Im looking to spend about 1000 to 1500 is it possible to get one with a 350 and installtion for that. How much for install Can you guys recommend some good engines.
Old Aug 28, 2001 | 11:40 AM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
You could probably get a used motor installed for that, but, it would be a USED motor....... Not necessarily a good thing.
You can buy a NEW motor for about that money, but, then you would have to have it installed. More money......
You will also run into trouble if you change induction systems. (tbi to tpi.....) If you are having someone else do the work, this can be translated to "big bucks".......
There are a lot of folks out there that remanufacture GM engines, and you can get just about any combination you could think of, but, the more esoteric it is, the more epxensive it will be. I think GM sells crate motors (pretty much a complete engine, less induction....) for pretty cheap for a replacement motor. (i.e. nothing special...)
Or, you could spend a grand on a beater, drive that while you save money to do your engine swap right.
Or, you could replace your headgaskets... and continue to drive your camaro.... You could prolly do the gaskets for under 300 bucks, paying someone else, or under 100 if you do it yourself.
Good luck.
Old Aug 28, 2001 | 04:19 PM
pronger44's Avatar
GM makes a crate motor for 1200. you would have to install it yourself though. it's a 350 4 bolt main that put's out about 240 HP. Go to www.paceparts.com
Linson
Oct 24, 2025 02:00 PM
Pac J
May 17, 2020 10:44 AM
FormulasOnly
Jul 23, 2018 08:47 AM
PAFORM350
Wheels and Tires
Oct 2, 2015 07:21 PM
Badass355ciz28
Sep 28, 2015 08:31 PM
