Cam bearings
Car: 1989 camaro
Engine: 350 sbc
Transmission: 9" tail th350 B&M stage 2 shift kit
Axle/Gears: 4.10
Cam bearings
Do i have to change my cam bearings if im buying a new cam or just
look over them and the surface on the cam to make sure there nice and smooth.
Thanks in advance for your replys
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Cam bearings
If they fall out of the block, they need to be changed. It's unlikely they'll ever get worn unless you have a very high mileage neglected engine.
Car: 1989 camaro
Engine: 350 sbc
Axle/Gears: 4.10
Re: Cam bearings
Thanks for your replys. Im changing the cam because I seen a cam lobe went flat when I was changing my oil pan.
