i would really like to go with a non computer-controlled carb, so how would i go about turning my car into a non-computer controlled? It's my 92 RS im swapping an 85 305 4bbl into it. Thanks guys in advance
Camaros:
1987 IROC-Z 350tpi
1992 RS 3.1L V6
Parts car: 1987 Z28
"A/C? Who needs A/C when you got t-tops?"
Camaros:
1987 IROC-Z 350tpi
1992 RS 3.1L V6
Parts car: 1987 Z28
five7kid
close
I hope you don't have to worry about emissions testing or inspection. If so, you need to reconsider what you're doing.
The basic V8 install has been covered many times on this forum. Take a look through the topics for the last month or so to see what you've got ahead of you.
The non-CC part is fairly simple. You need a mechanical/vacuum advance distributor with the power and tach wires going to it (should be able to use the current wires), and whatever coil goes with the distributor you choose; if your carb has electric choke, you'll need an ignition switched power source for it (best to use something other than the ignition power wire to avoid any drain from it); if you keep the in-tank electric pump, the power/relays/oil pressure switches for it, a pressure regulator to drop the pressure to carb levels (5-7 psig) and the tubing to get it up to the carb; if you go mechanical pump, remove the in-tank pump and put a piece of fuel hose in its place, and route the tubing from the tank to the pump to the carb.
Other than that, the throttle/TV cables, alternator wiring, etc. to accomodate the change in length between the two engines/systems.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4. 2.93 limited slip. 2-1/2" cat-back, ZZ3 intake, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 CC system w/'87 LB9 block, ZZ3 cam, ported World 305 heads, Hooker 2055 headers, 3" Catco cat & 3" catback, restalled TC, Spohn SFCs).
57 Bel Air, my 1st car. '66 396, 9.7 CR forged TRWs, Weiand Action+, Holley 750VS w/4150 conversion, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 600 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
