Vortec engine, cam, carb power question
Old Mar 19, 2012 | 06:11 PM
memphisboi's Avatar
hello guys . i have 84 camaro stock 700r trans and stock convertor. the engine is as follows. 95 sbc 350 block it has flat tappet cam so i went down street to comp cams and got this cam with max lift .470 flat tappet. i have stock vortec heads (906castin number) air gap intake with edelbrock 1406 carb. roller tip rockers will this setup work and how much horsepower will i have by way stock rear end plan on changin gears prolly 373 gear need suggestrions
Old Mar 20, 2012 | 06:29 AM
3rdgenmaro's Avatar
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
Re: Vortec engine, cam, carb power question
better check the heads for clearance.
When you give cam details, dont just give the lift. Need to post the LSA, duration, duration @.050, etc.
Never mentioned compression ratio either.
Old Mar 20, 2012 | 01:31 PM
s_s72623's Avatar
Have a 96 gmc 4x4 pickup, took out v-6 and put in 89 350 with carburator, anyone know correct timing, and plug gap? Answer would be much appreciated.
Old Mar 20, 2012 | 01:35 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
between 190 and 290hp depending on how lucky you got with your combo.
Old Mar 20, 2012 | 01:43 PM
s_s72623's Avatar
Have plenty of horsepower, just need correct timing and plug gap, thanks
Old Mar 20, 2012 | 06:34 PM
3rdgenmaro's Avatar
Car: 88 IROC
he wasnt talking to you. He was talking to the guy that created his own thread and asked a question.
I would suggest you do the same instead of hijacking someone elses. And to answer your question, just go to advance and get a set of Ac Delco plugs for that year engine and set the gap to .045. Timing around 32-34 Total.
Old Mar 22, 2012 | 08:16 AM
memphisboi's Avatar
sorry about not postin all the info
Specifications
lobe sepration 110. intake centerline 106 duration. 270 duration @ .50 lift is 224
valve lift is .470. lobe lift .313
its the comp cam 270h-10 magnum cam
engine is out of 95 surburban all stock except for cam and double roller timing chain. which i added. stock bore and stock piston
Old Mar 22, 2012 | 08:25 AM
memphisboi's Avatar
also when i adjust my rockers arm for valve when i rotate the engine to #6 tdc the rockers i adjusted on #1 tdc are all loose. my procedure is as follows
#1 tdc At this position, exhaust rockers 1, 3, 4, and 8 can be adjusted as can intake rockers 1, 2, 5, and 7. rotate crank Adjust exhaust rocker 2, 5, 6, and 7 and intake rockers 3, 4, 6, and 8 but most rockers i have already tighten are loose plz help i think ima buy us all a 24 case of beers to celebrate when i finally get finsihed
Old Mar 23, 2012 | 04:45 PM
Car: 1992 Camaro RS
So you have an all stock 95 Suburban engine with 96-99 Vortec heads?
I would estimate 300hp with 906 heads. If you have the stock 95 heads, 230hp.
Also, its normal for the other rockers to be loose. Just carry on the way you've been doing. Turn it back to #1 TDC and see if they're still loose. I bet they're not.
Frozer!!!
Jan 19, 2024 04:55 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
redmaroz
Aug 16, 2015 11:40 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
