3.4 DOHC
Old Sep 13, 2001 | 05:53 PM
HOT/A377's Avatar
3.4 DOHC
what is needed to put this in a thirdgen, also, would a TTA or Tubo regal computer control a turbo'd version of it?
Thanx
Old Sep 14, 2001 | 10:13 AM
FlameRedMetallic's Avatar
the 3.4 motor isn't that great of a motor. that is why it isn't very popular to modify like teh 3.8 or the 4.3 v6. i don't know for sure but i thinkit is a 60 degree v6 but i don't know if a rear wheel drive tranny would bolt to it or not. it would be super pain in the butt. if u wanna turbo v6 either but a TTA or get a drive train out of a turbo buick regal.
86 IROC-Z
305 TPI
700R4 W/ shift kit
3.23 gears
T-Tops
maroon with gold stickers and rims/ black interior
43,000 miles
flowmaster exhaust, edelbrock headers, gutted airbox, converter, and MAF, K&N filters.
soon to come are 3.73 gears and subframe connecters.
Old Sep 14, 2001 | 03:41 PM
Tas's Avatar
Tas
you'd need to bolt it to the tranny that came with a f-body, 2.8L, 3.1L or 3.4L v6. I doubt it would fit within the shock towers but it might be possible. GM shoved a big block and a DOHC ZR1 engine in before.
-Tas
'89 Formula WS-6
305, TBI, auto, 14x3 chrome flat based open element with K&N, Milodon 160* thermo, functional Formula hood, cross-flow Flowmaster, '99z28 rear pipes and tips....
To be installed eventually far far far into the future: Yours if the price is right and I don't have to ship :
Hooker 1-5/8" 50 state legal headers, Dynomax 3" I pipe (PN 44063 and 43248), Catco 3" cat, and injector spacer.
Super GRK_Taz World
F-Body Dual Exaust
EFI & Intake Options
AOL IM: superGRtaz
Old Sep 14, 2001 | 04:20 PM
91-ZZ4-Z28's Avatar
The 3.4 makes good power but even if you can get it in and running due to the fact it had a short production run parts will bite you.
If you must go V6 the 4.3 turbo from a GMC Typhoon or Syclon would be sweet and parts (other than intake, crank, and cam) are the same a 350.
1991 Z28 ZZ4 with LPE superram base, SLP runners, LPE 58mm T-body,Random Technology ramair,TES headers,24#svo injectors,ZEX nitrous,Walbro 255lph f-pump,Accel AFPR,Random Technology catback,!cats,and mutch more.
Old Sep 15, 2001 | 12:05 AM
Ryan_Alswede's Avatar
Car: 1992 Camaro RS & 1992 Camaro RS
Engine: 3.1 L v6 & 305 (5.0L) v8
Transmission: 4L60 Auto
No the DOHC 3.4L won't fit between the shock towers but the 3.4L push rod out of a 1993-1995 camaro will bolt right in,, go over to the V6 board and talk to KED85 he will fill you in, because he did the swap, if you have a V6 camaro, join the little club of the V6 board where you won't be put down for having a v6.
Old Sep 15, 2001 | 02:59 PM
Tas's Avatar
Tas
I wonder why the 3.4L DOHC wont fit if a ZR1 engine did. Maybe they banged in the shock towers a bit? the ZR1 engine should be even wider since its a 350 cid 90* engine. On the other hand Lotus designed the ZR1 heads very compact. They put the cams right over the valves and springs insted of using roller rockers like the Ford DOHC. Maybe since the ZR1 is 90* that the heads are wider but at a lower height. Since the 3.4L is 60* it probably doesn't get very wide till its very high up.
-Tas
'89 Formula WS-6
Super GRK_Taz World
F-Body Dual Exaust
AOL IM: superGRtaz
[This message has been edited by Tas (edited September 15, 2001).]
beltran89
Theoretical and Street Racing
46
Oct 7, 2015 07:36 PM
92projectcamaro
Sep 29, 2015 07:07 PM
92projectcamaro
Aug 6, 2015 01:20 PM
camaro6spd
Apr 20, 2001 07:42 PM
