Calling all TBI to TPI swappers!!Question regarding the wiring??
Old Sep 19, 2001 | 07:30 PM
jtmiller92's Avatar
Car: 1992 Camaro RS
Engine: 415ci LS3
Axle/Gears: 3.89
I'm putting a 91Z-28 TPI engine in my 92RS(tbi)..the Z was an auto car,I have the complete harness out of it.My RS is a 305/5speed car.Problem areas are the wiring harness connectors that connect to the underdash harness by the ecm and the wiring that connects to the firewall by the brake booster.Does anyone know what colors represent what?I know the connectors will plug in but they are pinned differently and the wire colors differ from the original...
92RS
Old Sep 19, 2001 | 10:21 PM
JRoy91RS's Avatar
Car: 91 RS Convertible
Engine: 355
Axle/Gears: 2.73 peg leg
Hmmmm...if your car is a 92 and the TPI is from a 91, they should be pinned the same. The connectors on your firewall by the brake booster are your fuel pump and fan relays and your ESC module (BTW I hope that you swapped you got a 350 ESC module). They should hook right up and all be the same color. I'm not quite sure what underdash harness you're talking about by the ECM. The VSS module? If you're usinga computer from a 90-92 the harness should plug right into the ECM. What colors do you need to identify? A good idea would be to get a Haynes manual for our cars, they have fair wiring diagrams.
Old Jun 5, 2002 | 11:21 AM
ERICCAMARO's Avatar
Car: 92 camaro Rs
Engine: 305 tpi
Transmission: t-5 WC
I took the harness out of a 91 t/a and have the same exact problem. When you hook up the two clear connectors right by the ecm none of the wires line up right? well you have to get the wiring diagrams heres one for tpi.
http://www.eecis.udel.edu/~davis/z28...730v8tpi-1.jpg
just change the last number it goes from 1 to 7 and it is all the wiring for a 92 tpi. youll have to find the one for the tpi. have fun
BRoss99
Aug 10, 2025 05:08 PM
MustangBeater20
Oct 29, 2022 09:20 PM
Vintageracer
Jan 10, 2020 05:33 PM
redmaroz
Aug 16, 2015 11:40 PM
92purpz28
Aug 11, 2015 02:30 PM
