i have questions for those of you that have swapped in a NON-CC engine
Old Sep 19, 2001 | 06:16 PM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
Transmission: TH-700R4
Axle/Gears: GM Axles and GM 3.73
first off.....what would i have to do bout emissions and stuff??
would i have to get a non-locking TC
what would happen if i just unplugged and took out the computer and then dropped in the engine??
i am totally lost and i plan on doing this....so if you could....PLEASE help
thanks
84TA T-tops L-69 305HO TH-700R4 stock 190hp and 240 ft-lbs.
new best E.T. (dont laugh) 15.986 @84.93mph
old best E.T 15.997@86.04
http://www.geocities.com/K_towngangsta
Mods-
K&N Air filter
Old Sep 19, 2001 | 11:31 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
The emmisions stuff can go back on the car without the computer, the smog pump doesent have any electrical wires and should be considered a pully with air lines on it.
If your engine runs now I suggest that you buy a non cc distributor and carb and put them on it now so you can cut some of the wire mess out of your car now. Its easyer now than later. The distributor and carb are a very easy swap it just remove and replace.
Your transmittion will be fine w/o locking up on the highway lock up occurs at 40+mph stabel speed. Most of the time its not locked up at all. The transmittion will run a bit hotter so get a small trans cooler to help it out.
You will get a check engine light when you disconnect the computer so you will need to ground the black with brown stripe wire that is on the plugin for the computer. This will shut the light off.
Its a very easy job.
Good luck!
SSC
Old Sep 19, 2001 | 11:32 PM
slowV8berlinetta's Avatar
Keep the ecm, just to keep the tranny hooked up, then you can run a switch between the a and f terminals of the dlc to lock up the converter. there is a tech article on this, and i will be doing it in the next two weeks when i swap out my carb and dist
'84 Berlinetta, LG4, 700R-4, starwars interior, falling headliner, T/A t-handle shifter, trans cooler, more to come in time and $$ www.hipergp@aol.com
Frozer!!!
Jan 19, 2024 04:55 PM
jharrison5
Aug 19, 2015 05:53 PM
redmaroz
Aug 16, 2015 11:40 PM
reiderz iroc
Aug 13, 2015 04:57 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
