LT1=MiniRam
Old May 11, 2001 | 09:23 PM
camaro6spd's Avatar
LT1=MiniRam
If you took a 350 block and put a LT1 cam and a MiniRam on it, wouldn't it be just the the LT-1 except the reversed cooling?? What kind of hp could you get with a MiniRam and LT-1 Cam?
Old May 11, 2001 | 09:49 PM
camaro6spd's Avatar
Could I buy a LT1 Intake and slap it on there??
[This message has been edited by camaro6spd (edited May 11, 2001).]
Old May 11, 2001 | 11:28 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
The MiniRam is essentially the LT-1 intake... or rather the other way around since TPIS thought of it first. The LT-1 also has larger intake and exhaust ports than the previous L98 motors. If you're going to buy a cam stay away from regular production cams. They are weak performers. The after market affords much better power with the same driveability.
Old May 12, 2001 | 02:43 AM
Ray87Z's Avatar
Car: 94 Z28
Engine: LT1 w/ headers, catback, CAI, tune
Axle/Gears: 3.23s
If you want a close match to a LT1 motor snag the Vortec heads and the MiniRam that fits them. You'd virtually have a iron headed, standard flow LT1 engine... LOL.
Ray87Z
-Vortec headed 350.
86 IROC w/ a cammed 305 TPI.
Formerly Ray86IROC.
www.inter-scape.com/Ray
Old May 12, 2001 | 04:54 PM
camaro6spd's Avatar
so i could not just bolt on the LT-1 Intake, and what is up with the reversed cooling, what is different about it?
Old May 12, 2001 | 05:53 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
<font face="Verdana, Arial" size="2">Originally posted by camaro6spd:
so i could not just bolt on the LT-1 Intake, and what is up with the reversed cooling, what is different about it?</font>
Nope sorry the LT1 intake has different water passages for the reverse cooling, 8 bolts as opposed to 12 that hold a reg sbc intake down and no hole for the distributor since it uses the front mounted opti, belive it has been done but it would probably cost more to make it work than just buying a miniram and the reverse flow cooling cools the heads in order to decrease detonation with its stock 10.4:1 c/r.
Old Sep 19, 2001 | 09:11 PM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
LT1 has 12 bolts and the exact same ports as a TPI or carb intake base. It will fit with a few mods.
86 Camaro Sport
383 Speed-O-Motive Crate Engine, Raptor 700R4 Tranmission, Trick Flow Twisted Wedge G2's, 58mm Accel TB, 3.73 Auburn Pro, SLP Cold Air Induction and Headers, Hooker Cat-back, Serpentine Belt Setup, Dual IROC Fans, Jamex springs, 16" IROC Rims, 36mm/24mm Sway Bars, Global West Steering Brace. Hotchkis Rear LCA's,Panhard Bar and SFC's.
My Camaro Project
Old Sep 19, 2001 | 10:02 PM
ahusted's Avatar
John, Don't leave me hanging like that!!! Is it possible and reasonable ($wise) to use an LT1 intake on a "old style" block? This could help me keep building on my 87 T/A 5sp instead of buying another 4th gen!!!!
Old Sep 19, 2001 | 10:25 PM
Tas's Avatar
Tas
yes its possible if you have a machiest for a friend. You'd need to change the intake bolt pattern, drill and maybe weld in a spot for the distributer, and figure out how to add a water passage in front with a thermostat. Holley has a single plane intake for $255 just get that. check the intake link in my sig
-Tas
'89 Formula WS-6
305, TBI, auto, 14x3 chrome flat based open element with K&N, Milodon 160* thermo, functional Formula hood, cross-flow Flowmaster, '99z28 rear pipes and tips....
To be installed eventually far far far into the future: Yours if the price is right and I don't have to ship :
Hooker 1-5/8" 50 state legal headers, Dynomax 3" I pipe (PN 44063 and 43248), Catco 3" cat, and injector spacer.
Super GRK_Taz World
F-Body Dual Exaust
EFI & Intake Options
AOL IM: superGRtaz
Old Sep 20, 2001 | 05:29 AM
Engine: 4.0L
Ok, ok, I'll pass along what I know since it will be a tech article soon
after it's up and running. There are several problems with the STOCK LT1
intake but the ports and coolant passages are not one of them. What I did
before I started was get a cheap $6 intake gasket from DAP and just layed it
on the intake (already off the car), everything was perfect except for some
of the mounting holes, the 4 corner ones were good. No problem, I took the
gasket as a templet and drilled the new holes in the intake, no more
problem.
Problem #2, in case you havn't noticed there's no rear distributer on a LT1.
I had to drill the hole for it, warning-this hole must be in perfect
location. I used a old TPI base and made an aluminum templet utilizing the
rear two mounting holes to locate the dist hole. Distributer must be shimmed
about 1/4" higher due to the shortness of the LT1 intake. Also must use the
small HEI distributer with remote coil found on 1987-later.
Problem #3, No front coolant passages to return to the radiator. Well, I
just drilled and tapped two 3/4" heater nipples vertically where the coolant
would normally exit the head. I will run 3/4" heater hose to a remote
thermastat housing I found on-line. it will be mounted on the fenderwell. It
will use the same outlet neck and return to the radiator as it should.
Problem #4, must have custom fuel lines made to attach to the fuel rail of
the LT1. About $40 if you supply the ends. Available from Pep Boys.
86 Camaro Sport
My Camaro Project
[This message has been edited by John Millican (edited September 20, 2001).]
Old Sep 20, 2001 | 08:31 AM
Damon's Avatar
That's great info! Can't wait to read the full tech article on that. A junkyard LT-1 intake plus a few hundred for machine work beats the heck out of a complete Miniram's cost.
The miniram does have a larger plenum area and larger runners than a stock LT-1, though. It's freakin' CAVERNOUS in there! You can hear echos!
Old Sep 20, 2001 | 02:44 PM
Engine: 4.0L
<font face="Verdana, Arial" size="2">Originally posted by Damon:
.......... A junkyard LT-1 intake plus a few hundred for machine work beats the heck out of a complete Miniram's cost..........</font>
A junkyard LT1 intake, now that's a laugh. When was the last time anyone has seen a LT1 in a junkyard? Almost never I'll bet and if so good luck getting only the intake, they're most likly to sell the whole engine.
86 Camaro Sport
My Camaro Project
Old Sep 20, 2001 | 04:33 PM
Tas's Avatar
Tas
I used to see LT1 intakes at www.camaroz28.com in the for sale section. I almost got one for $50 one time.
Old Sep 20, 2001 | 05:40 PM
ahusted's Avatar
John, If you don't mind what do you think the swap will cost? Its the whole the money saved worth the time and effort thing. Thanks
Old Sep 20, 2001 | 07:38 PM
Engine: 4.0L
<font face="Verdana, Arial" size="2">Originally posted by ahusted:
John, If you don't mind what do you think the swap will cost? Its the whole the money saved worth the time and effort thing. Thanks </font>
I would say between $250-500 depending on what bargains you get, what your converting from and the quality of material need. For example, high pressure rubber fuel lines or steel braided, see what I mean? Rubber were $60, braided would be $120.
After the test runs this weekends I might be able to put modded kits together so it will be a bolt-on for people that can't do the work required. They would be totally complete minus injectors, throttle body and distributer. Would there be a market for such a kit? Anyone interested?
86 Camaro Sport
My Camaro Project
Old Sep 20, 2001 | 08:21 PM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
Good stuff. I'd be interested in finding out what happens with the LT1 intake. I'm sure most thought about the swap before, but probably never went through with the plan.
I think there is a market for an LT1 kit. The LT1 intake is from what I've heard, much superior than the miniram because of it's equal length runner passages.
I don't think TPIS would be happy though.
Old Sep 21, 2001 | 10:50 AM
Matt98SS's Avatar
a single plane carb intake converted for EFI would work better.
This is a great idea and sounds like fun.
But if you want max performance it is not with the LT1 intake
Old Sep 21, 2001 | 10:52 AM
Matt98SS's Avatar
its also kinda funny cause maybe just a year ago everyone was saying the miniram was a waste and the TPI set up was better than LT1 intake wise, casue of low end 1500 RPM TQ that in real life you never even see.
Old Sep 21, 2001 | 02:21 PM
Tas's Avatar
Tas
https://www.thirdgen.org/messgboard/...ML/004484.html
Old Sep 21, 2001 | 08:05 PM
ahusted's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Matt98SS:
</font>
Whats wrong with the LT1 intake? Runs pretty darn good on my 97Z!! And can't be any worse than TPI.
Old Sep 26, 2001 | 09:05 PM
Engine: 4.0L
Update.......finished picture attached. Runs great, lost some low end torque. i'm taking this to the track Sunday.
86 Camaro Sport
My Camaro Project
Old Sep 26, 2001 | 10:37 PM
RyanSS's Avatar
Does the throttle body for a TPI work on an LT1?
How did you do the injectors?
89 RS parts car
Daily driver 91 RS auto LO3 70k, 14x3 K&N Open element, cat-back delete.
Coming soon: 350, headers, loudmouth exhaust.
Old Sep 27, 2001 | 05:17 AM
Engine: 4.0L
<font face="Verdana, Arial" size="2">Originally posted by RyanSS:
</font>
I re-used my throttle body and injectors from my TPI I removed.
Old Sep 27, 2001 | 10:00 PM
RyanSS's Avatar
You gotta let us know when the tech artical is up. This is great news!!
89 RS parts car
gixxer92
Apr 12, 2022 12:09 AM
88SS6SPEED
Nov 11, 2015 07:05 AM
L0tuS
Oct 4, 2015 08:07 AM
WejaZ28
Oct 3, 2015 07:38 PM
L0tuS
Sep 4, 2015 11:16 PM
