305 - 350
Old Sep 26, 2001 | 08:27 PM
ImportsRsloths's Avatar
305 - 350
I have a 88 IROC Z 305 TPI 5 speed.... my 305 blew like 3 rods racing a mustang. I need a new engine.... a guy close to me has a 350 out of an 87 iroc.... im gonna put a zz3 cam, world products s/r torquer heads (2.02, 1.60 and ported out) and im gonna freshen up the block (it has 70K) with some TRW hypernautic pistons .030 over with rings and some other stuff..... is there anything i have to worry about ahead of time etc ANYTHING will the 350 block be a bolt in?? i know i well need 22# fuel inj or an AFPR, and 350 knock module..... ANY CONERCERNS OR HELP IS WANTED... also i have an extra plenum and manifold im gonna port out. and the tranny is getting a solid rebuild done to it.
Old Sep 26, 2001 | 10:20 PM
RODS92Z's Avatar
GO for 24lb injectors and a aftermarket chip.
And maybe a better clutch to take the power.
1992 Camaro Z-28 custom 25th anniversary, 5.7 TPI auto, 2.73 posi, t-tops, arctic white with 92' medium mettalic gray stripes with black border stripe.
1967 Pontiac Catalina 2 door fastback, 400 v-8, auto, cameo white, dark red interior
Old Sep 27, 2001 | 04:26 PM
ttt this is important stuff
Old Sep 27, 2001 | 05:41 PM
David Petersen's Avatar
Do you have sub frame connectors? Especally if you have T tops this would be a good bit of insurance to keep the Camaro's hard lines straight.
Old Sep 28, 2001 | 02:02 AM
chevySS's Avatar
<font face="Verdana, Arial" size="2">Originally posted by David Petersen:
Do you have sub frame connectors? Especally if you have T tops this would be a good bit of insurance to keep the Camaro's hard lines straight. </font>
Yeah I agree with David, with that engine it sounds like you are gonna be making somewhere in the 300-350 HP ballpark, and a good bit of torque as well, you might wanna look into subframe connectors, and maybe a stronger rear end too, especially if you ever plan on running drag radials.
Teal Green 91 Camaro RS
305, Automatic Tranny
Stock for now
[This message has been edited by chevySS (edited September 28, 2001).]
xkingcodex
Feb 12, 2020 07:43 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Dwayne614
Sep 28, 2015 08:33 AM
theurge
Aug 21, 2015 12:46 PM
st.evel07
Aug 13, 2015 06:15 PM
