Question about swapping 305TPI to 350 carb...
Car: 87 Iroc Z
Engine: 383ci.
Transmission: WC-T5
OK its a 5.0 TPI coming out and a 350 from a 1970 Monte Carlo going in. The question is about the harmonic balacer. Do I keep the one on the 305 or do I put it on the 350. The 350 was originally with an auto tranny in is being bolted to a T5. Does this make a difference. I think I should keep the one that came with the 350 in 1970 on the 350. Am I wrong?
Car: 1991 Z-28
Transmission: T-5 (gonna buy the farm)
As far as the balancer goes, you are right. Keep the 350 one. The flywheel from the 305 won't work on the 350, if the 305 is newer than 86 I believe. The 70 has a 1pc. rear main. You would need to buy a 2pc. rear main flywheel of the same diameter, 153 teeth, to make it bolt up. You didn't mention any problems with that so you may have that figured out already.
Joshua Johnston
1991 Z-28
350, T-5, K&N, Ported Vortec heads, Edelbrock RPM, Holley 750 D.P., HEI, 11.07:1 CR, Comp Cams Roller-.510"/.520"-282*/288* dur., Shorty Headers, Dual 2.5 Exhaust,Dynomax Bullet Mufflers, T&R Motorsports custom air intake
Joshua Johnston
1991 Z-28
Transmission: 4L80E/4L80E
<font face="Verdana, Arial" size="2">Originally posted by johnsjj2:
...The 70 has a 1pc. rear main. You would need to buy a 2pc. rear main flywheel of the same diameter...
</font>
</font>
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4. 2.93 limited slip. 2-1/2" cat-back, ZZ3 intake, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 CC system w/'87 LB9 block, ZZ3 cam, ported World 305 heads, Hooker 2055 headers, 3" Catco cat & 3" catback, restalled TC, Spohn SFCs).
57 Bel Air, my 1st car. '66 396, 9.7 CR forged TRWs, Weiand Action+, Holley 750VS w/4150 conversion, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 600 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
[This message has been edited by five7kid (edited October 04, 2001).]
Car: 1991 Z-28
Thanks five7, I meesed that up.
Joshua Johnston
1991 Z-28
Joshua Johnston
1991 Z-28
