Would this work??
Old Feb 11, 2010 | 09:03 AM
megtom2's Avatar
Car: 1989 Pontiac Formula 350
Engine: 350 tpi
Transmission: 700
Would this work??
Trying to line up a decent rebuilt engine that will bump the L98 power a little and not break the bank for my 1989 Formula.
I have found a rebuilt 350 late 80's block.
I found some vortec heads cast 906.
I know I will have to pony up the dough for a Vortec/TPI intake.
Will this setup work fine? Just learning about all of this technical stuff so I thought I would ask.
Old Feb 11, 2010 | 11:00 AM
88Trans-am's Avatar
Car: 88 GTA Trans-am
Engine: 350 vortec TPI(in process)
Transmission: 700-R4
Axle/Gears: 3.27 LSD
Re: Would this work??
Go with a Holley Stealth Ram intake, it's cheaper than the vortec TPI base and you get more top end power.
Old Feb 11, 2010 | 03:14 PM
zraffz's Avatar
Car: 1987 Camaro
Engine: LQ9
Axle/Gears: 4.10
Don't buy 906's, they suck. You want 4681? I believe it is but google it to double check.
Old Feb 11, 2010 | 06:02 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Compared to what?
Old Feb 11, 2010 | 08:09 PM
megtom2's Avatar
Engine: 350 tpi
Transmission: 700
So the 906's won't outperform stock heads?
Also if I go with the 906's on top of a 350 block will I need to mess with the prom or will all of the computer stuff work ok?
From reading all over this site and others the 906 sound fine.
Old Feb 11, 2010 | 08:39 PM
megtom2's Avatar
Engine: 350 tpi
Transmission: 700
From what I read you have to buy fuel rails and the cost goes over the vortec tpi manifold. It also looks to be higher than the stock plenum.
Old Feb 22, 2010 | 10:50 PM
83 Crossfire TA's Avatar
906's are fine, there was originally some argument that they were meant for HD applications and didn't get as well a flowing valve job (valve seat inserts?) in exchange for durability, but they are basically the same port and chamber design.
They should be significantly better than the late 80's 350 heads.
Terrell351
Jun 13, 2021 01:13 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Vintageracer
Jan 10, 2020 05:33 PM
Jk_Under
Aug 17, 2015 03:08 PM
Fronzizzle
Aug 17, 2015 02:52 PM
