Online Swap Archives
ede if i could kick you i would... I look i find none here. There are posts but they dont really tell me anything. I look in old posts also find NOTHING. comeon sum help here?
Transmission: 4L80E/4L80E
What kind of information are you looking for?
If you want something that has details like, "Step 1: Open the hood by pulling the release lever on the driver's side kick panel" and the last step says "Close the hood and take the car for a test drive", I doubt you're going to find that anywhere.
There used to be engine swap books out there because life was simpler in the good ol' days. For instance, in 1957 every Chevrolet passenger car had the same basic chassis (Corvettes excluded). The low-buck economy 6-cylinder 3-on-the-tree sedan had a lot in common with the top-of-the-line high compression fuel injected solid lifter Nomad.
That just isn't the case anymore. Your desire to put a V8 in a factory V6 car is a perfect example. What it takes is a fair amount of underhood experience and some ability to think outside the box. Too many variables for someone to have done that for you already.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4. 2.93 limited slip. 2-1/2" cat-back, ZZ3 intake, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 CC system w/'87 LB9 block, ZZ3 cam, ported World 305 heads, Hooker 2055 headers, 3" Catco cat & 3" catback, restalled TC, Spohn SFCs).
57 Bel Air, my 1st car. '66 396, 9.7 CR forged TRWs, Weiand Action+, Holley 750VS w/4150 conversion, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 600 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
Street Lethal
Apr 30, 2019 12:14 PM
