89 305 tpi swap to a possible 383
Old Feb 13, 2010 | 02:42 AM
Gtuck's Avatar
Car: 1989 Iroc-z, 1997 Gmc Sierra
Engine: 383 stroker*new*
Transmission: Built 700r4
Axle/Gears: highway car(2.73)
I have recently begun the search for a new motor for my 89 iroc
and have stumbled upon a 350 from a 1970's Gm pickup, i am planning on boring and stroking such motor but before i headed down this path i wanted a little advice
I plan on using the tpi system from my 305, is this an easy path or should i switch to a carb
Also if i were to keep the Tpi would i be able to modify my current heads or should i find 350 heads or aftermarket (i'm not trying to race this car only add a little more kick)
Any comments help Thanks
Old Feb 13, 2010 | 12:38 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Welcome aboard thirdgen.org.
'87-'92 350 heads would solve the problem. You could even use your 305 heads (same ports) if you were willing to install larger intake valves, do port clean-up, and choose pistons to keep compression reasonable.
Old Feb 13, 2010 | 01:57 PM
SeanW's Avatar
Re: 89 305 tpi swap to a possible 383
You will be amazed at what some aftermarket heads and a cam swap will do to wake up that motor.
Your TPI system ultimately limits your RPM potential. Stock they rev very low. If you go with an aftermarket TPI and/or heavy intake porting you can get a bit more out of them but its runner length that is the real issue. If going with a carb is not a legal issue for you then it will certainly be the easier route to power.
Old Feb 14, 2010 | 09:24 PM
Gtuck's Avatar
any good aftermarket parts you would recommend, i wish to stay with the tpi
Old Feb 18, 2010 | 02:28 AM
Gtuck's Avatar
some cylinder heads that i have been contemplating
http://www.edelbrock.com/automotive_...erformer.shtml
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
drewdock87
South Central
Aug 18, 2015 09:02 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
