in the 12s?
Old Oct 4, 2001 | 02:01 PM
92Z1LE's Avatar
in the 12s?
Within a year I'd like to swap the LB9 for something that will put me in the 12s. I'd like some opinions on the best bang for the buck to get me there. Should I do an LT1 swap, have an engine built, find some other used engine, etc. Also, what else will I have to beef up to handle the power? Will the stock tranny, clutch, and rear end hold up? The car will not be my daily driver, but I want something reliable that will run on pump gas, preferably N/A. Also, since it's a 1LE would you guys recommend keeping the original engine? It has some basic performance upgrades, so it's not original. Thanks in advance for the opinions.
92 Z28 1LE 25th Anniversary Heritage Package
LB9 w/5-speed
Hooker Headers, Edelbrock exhaust, K&N filters
Old Oct 4, 2001 | 02:19 PM
L98IROCZ89's Avatar
Car: 1989 IROC-Z
Engine: 350 Vortech Supercharged ZZ4 TPI
ZZ502, ditch TPI for carb!
1989 Chevrolet Camaro IROC-Z
L98 - 350c.i. TPI, rebuilt 700R4 auto w/shift kit, Dual catalyst Monza PaceSetter Cat-Back, SLP 1 5/8 Coated Headers, 3.23 Posi rear, Hypertech chip with 160stat, MSD 6A, Under-Drive pulleys, AFPR, K&N's, !Air Box w/ Ram Air, moddified MAF, !TB Coolant, Spohn Dual Cat SubFrame Connectors, Alarm, Keyless entry, remote starter, 92 Z28 AeroWing, Brand New Paint (6/21/01)
Future: ZZ4 TPI w/EGR, T56, 3.42 or 3.73, Spohn strut tower brace and LCA's, Accell 24# injectors
1989 Chevrolet Celebrity Eurosport <--DEAD AS OF 9/20/01
2.8 MPFI, no mods
225,000 miles and still ticking!
More info and pics on my webpage:http://go.to/iroc-z
AOL IMer: GPA 0point0
Old Oct 4, 2001 | 08:34 PM
87_T/A_LB9's Avatar
If I were you I wouldn't touch the car. I'd leave it original. 3rd gens don't sell for that much. Pick one up with a bad drivetrain and then do your buildup. That 1LE has a very good chance of being collectible. Sort of like the 69 Z28s(or was it the SSs) with the 302. Leave it the way it is.
Old Oct 4, 2001 | 08:44 PM
92Z1LE's Avatar
I thought about going to a carb, but wasn't sure what it would take to change it over. It would be alot easier just to buy a crate motor with a carb. I think if I do the engine swap I'll keep the original engine just in case 1LEs do become collectable.
Old Oct 5, 2001 | 04:07 PM
JPrevost's Avatar
Car: 91 Red Sled
Just in case they do....HA....they already are!
, Jon (350 TBI!)
91 Red My website
Old Oct 17, 2001 | 07:08 PM
Z03Z28's Avatar
Car: 92Z28,98LegacyGT,ZX9R,91 Z28,02 Z71
Engine: 350,307,2.5,900cc,5.0
Transmission: 700r4,4spd auto,700r4,4L80
Axle/Gears: 323,?,323,?,373
If you must go 12's get another motor
and a richmond trans a 383 should put
you in the 12's.But you should leave
that car alone.Maybe get a cheap one
with a blown motor or trans .
86Sprtcpe
Car Audio
Dec 13, 2001 06:11 PM
305IrocZ28
Car Audio
Oct 22, 2001 08:58 PM
MelloYello
Jun 21, 2001 07:15 AM
FTC
Car Audio
Apr 6, 2001 01:23 PM
polagrilr
Car Audio
Mar 18, 2001 08:18 PM
