is swapping a 2.8 mfi to a v8 carb difficult?
Old Oct 21, 2001 | 08:51 PM
85berlinetta19's Avatar
I am wanting to take out my 2.8 mfi in my 85 berlinetta and changing it to a carbureted v8. Will I be getting in over my head or is this a reasonable process? All help is greatly appreciated.
Old Oct 22, 2001 | 11:12 AM
300hpse's Avatar
Car: 1990 Trans Am
Engine: Lb9
Transmission: factory T5
Axle/Gears: 3.08 limited slip
it all depends on how much you can spend and how much you can do. This swap will require an entirely new engine, intake, exaust, carb, ecm, and the biggest pain, a transmission. You can pick these up used in good shape for some money though or find a donor car (aka a 305 f-body) and use everything but switch the block. This is your cheapest way.
1983 Firebird S/E
308hp@5000rpm, 389ft/lbs@2300rpm.
Old Oct 23, 2001 | 12:57 PM
shiner16's Avatar
I'm right smack dab in the middle of the process right now. Most of the headaches have been taken care of and/or figured out. I don't have web access very often, email me at dtuom@juno.com if you want any helpful hints, any questions, anything I could help you with. Good luck.
Old Oct 23, 2001 | 03:46 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Old Oct 23, 2001 | 05:11 PM
Bill86Z's Avatar
Don't forget to change the radiator to a V-8 version, if you don't you will over heat like crazy.
Old Oct 24, 2001 | 11:42 PM
300hpse's Avatar
Car: 1990 Trans Am
Engine: Lb9
um incase you didnt know the q-jets on these things are completely electronically controlled. If he goes with a non comp controlled carb, wont the computer freak especially if it cant recognize injecors or any fuel control at all? Not to mention the starter and distributer and O2 sensor. He needs to find a donor v8 fbody and strip all electronics and everything.. Not to mention the fact of emissions.
Old Oct 25, 2001 | 09:55 PM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
<font face="Verdana, Arial" size="2">Originally posted by 300hpse:
um incase you didnt know the q-jets on these things are completely electronically controlled. If he goes with a non comp controlled carb, wont the computer freak especially if it cant recognize injecors or any fuel control at all? Not to mention the starter and distributer and O2 sensor. He needs to find a donor v8 fbody and strip all electronics and everything.. Not to mention the fact of emissions.</font>
well, thats why you dont use the computer
the SES idiot light will come on
PULL THE BULB
computer will be pronounced clinically dead, and thats a good thing
next (optional) GET RIDDA THE A I R PUMP
cuz you prolly wont pass emissions anyway
then find someone who will pass you
best bet if you dont know anyone is a garage and slip the guy some $$
knightrider89
Jan 14, 2020 06:56 PM
tj19985
Jan 7, 2014 01:08 PM
typevoid
Aug 24, 2003 05:04 AM
kptkid
Jan 21, 2003 09:41 PM
Blitzd4evr
Carburetors
Apr 30, 2002 02:46 PM
