lt1 intake on a 88tpi motor
Old Oct 25, 2001 | 10:14 PM
1988camaroZ's Avatar
i have heard that this works but i am not sure what is all needed for this to proerply work but am curious and have my hands on an lt1/4 intake if n e one knows how this may be done let me know
Old Oct 26, 2001 | 01:36 AM
Tas's Avatar
Tas
check the TPI board. You need to get a hole for the distributor machined, redrill the intake for tradtional bolt holes, and route the front waterpassages to a remote thermostat housing.
-Tas
'89 Formula WS.6
Old Oct 26, 2001 | 09:17 AM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
http://members.home.net/millicanga/s...into_a_1st.htm
86 Camaro Sport
LT1 Induction
383 Speed-O-Motive Crate Engine, Raptor 700R4 Tranmission, Trick Flow Twisted Wedge G2's, 58mm Accel TB, 3.73 Auburn Pro, SLP Cold Air Induction and Headers, Hooker Cat-back, Serpentine Belt Setup, Dual IROC Fans, Jamex springs, 16" IROC Rims, 36mm/24mm Sway Bars, Global West Steering Brace. Hotchkis Rear LCA's,Panhard Bar and SFC's.
My Camaro Project
Moderator at SE ThirdGen
Old Oct 26, 2001 | 04:23 PM
did u notice a big differnce cause i am deciding between porting mine , and after market one or the lt1 intake and i wanted to see how much work its was going to be. And i think i am gonna stick with porting mine or and aftermarket
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
NBrehm
Aug 25, 2015 11:49 PM
86White_T/A305
Aug 17, 2015 12:16 AM
