weird problemss after engine swap please help
Old Oct 22, 2001 | 07:09 PM
BOTTLEDZ28's Avatar
Transmission: A4
I installed a new GM crate 350 motor in my 91z28 and used all my old tpi stuff. the motor was complete already except for a intake I am trying to set timing but when I disconnect the brown wire to set timing, the car dies. also when wire is connected, the car has lopy idle. If i check the timing mark with the connector connected, it moves between 3 and 10 degrees.
another problem is smoke coming from oil dipstick, if i pull the PCV valve then smoke comes pouring from the valve cover,what could this be. please help i have more tiny problems but i need these fixed right now
Old Oct 23, 2001 | 07:20 AM
crucial's Avatar
The timing is easy. Advance the distributor until the car stops dieing! Smoke pouring out of the valve cover is BAD! That could indicate bad rings!!
1991 Z28 5.7 TPI
ZZ4 heads, ZZ4 cam, Harland Sharp roller rockers, Accel base, SLP siamesed runners, 52MM SLP Throttle Body, Hooker Headers, Flowmaster catback, MSD6A ignition, Home made ramair system, 2500 stall, bullet proof 700R4, aluminum driveshaft...
Soon to be installed. WC T5 !
Old Oct 23, 2001 | 08:13 PM
BOTTLEDZ28's Avatar
Transmission: A4
i cant have bad rings the motor has about 5 miles on it. it is a GM crate motor. all I did was put my tpi setup on it.
Old Oct 26, 2001 | 06:24 PM
jamesbern's Avatar
You don't have bad rings, they just aren't seated yet.
Old Oct 27, 2001 | 08:23 AM
BOTTLEDZ28's Avatar
Transmission: A4
so could the smoke be because the rings are seating? also should i move distibutor withthe brown wire dissconected or connected. the car dies wheni disconnect it
Frozer!!!
Jan 19, 2024 04:55 PM
camaro11j
Sep 19, 2018 08:49 AM
theshackle
Mar 5, 2017 06:37 PM
sreZ28
Aug 14, 2015 07:48 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
