Turbo V6: 3.8 or 4.3?
Old Oct 31, 2001 | 12:47 PM
91z4me's Avatar
If you had the opportunity which would be easier? TTA 3.8 or Syclone 4.3?
91 z-28 305 700R4
3.73 gears out back
T-Tops and Black all over.
Old Oct 31, 2001 | 05:35 PM
mat89RS's Avatar
I'd go with the TTA 3.8 and do a turbo upgrade,the weight of the motor is awesome. If you're serious about doing it, it's alot of hard work. 4.3 uses the same motor mount, engine is the same size as a v8, however you would have to do major wiring for both...
LT1 POWERED
HEADMANS HEADERS
300 HP backed with a limited slip, 2.73.
Top speed reached: 150 mph
EATS MUSTANGS FOR BREAKFAST
Old Nov 1, 2001 | 10:57 AM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
I'd guess the 4.3 would be easier, it uses regular sbc acessories which you could do alt. water and p/s all on drivers side and leave the pass side for the turbo, as said the mounts are the same for the 4.3 and V8 and existing V8 transmissions would also bolt up.
Old Nov 1, 2001 | 03:28 PM
91z4me's Avatar
Also which would be faster???
91 z-28 305 700R4
3.73 gears out back
Old Nov 1, 2001 | 03:46 PM
SoCo80p's Avatar
the GN engine forsure, theres a million more mods to do on them then the chevy 6, there many a GN in the 7's in the 1/4
Old Nov 1, 2001 | 06:10 PM
ede's Avatar
ede
reguardless of whats been posted here a 4.3 will not just drop in and bolt up and doesn't use the same motor mount location. i ought to know i have one in a 85 camaro drag car. i'd go with a 3.8 if i were you and had access to one.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
cheesehomer
Dec 31, 2015 08:48 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
bjpotter
Oct 4, 2015 07:48 PM
customblackbird
Oct 1, 2015 04:30 PM
New2Chevy
Sep 28, 2015 12:35 AM
