blown up 305
Old Feb 21, 2010 | 08:47 AM
88usa1's Avatar
Car: 1988 camaro
Engine: 305 tbi
Transmission: 700r
Axle/Gears: 3.73 posi
blown up 305
I need help.My 305 in my 88 camaro is done.I pulled it out with the 700r attached.The problem is i can not seperate the trans and the engine because the engine is locked up.So i can not get to the bolts on the flywheel/converter.Any ideas would be a big help.
Old Feb 21, 2010 | 09:10 AM
ternandes's Avatar
Car: 88 GTA
Transmission: WC T5
Axle/Gears: BW 9-bolt 3.27 posi
Re: blown up 305
It is possible to remove the trans with the torque converter still attached to the flywheel. It slips into the front pump on splined shafts. You need to be careful to support the weight of the tranny as you remove it to avoid damage to the pump.
Old Feb 21, 2010 | 09:11 AM
one92rs's Avatar
Car: SOLD!!!!!
Re: blown up 305
unbolt the trans and puyll it off leaving the converter attached to the engine. then get the bolts off after.
Old Feb 21, 2010 | 09:23 AM
88usa1's Avatar
Car: 1988 camaro
Engine: 305 tbi
Transmission: 700r
Re: blown up 305
Thanks for the help.I will give that a try.
Old Feb 22, 2010 | 06:47 AM
88usa1's Avatar
Car: 1988 camaro
Engine: 305 tbi
Transmission: 700r
Re: blown up 305
thanks guys--you were right
Old Feb 22, 2010 | 11:43 AM
ternandes's Avatar
Car: 88 GTA
Transmission: WC T5
Re: blown up 305
Glad to help. BTW, stick with this board. You will be amazed at the resources that are available here, plus lots of people eager to help.
db057
Apr 28, 2019 07:45 AM
GouldyGTR
Sep 7, 2015 09:05 PM
buffaloman
Firebirds Wanted
Sep 7, 2015 09:47 AM
buffaloman
Camaros Wanted
Sep 7, 2015 09:46 AM
Formula_88AE
Sep 3, 2015 01:47 PM
