Need cam any suggestions pease!!!
Old Feb 21, 2010 | 03:38 PM
355sbc's Avatar
Car: 1989 camaro
Engine: 350 sbc
Transmission: 9" tail th350 B&M stage 2 shift kit
Axle/Gears: 4.10
I have a standard 350 with stock heads, Torker 2 intake, MSD streetfire hei, 4v relief flat top pistons, 1406 edel carb, the exhaust is heddman LT's running to super 44 flowmasters dumped before the axle. The trans is th350 with 3000 stall, rear gears are 4.10's.
I was looking at the comp xe274h would that be a good cam for this setup
I plan on getting new springs with whatever cam I choose in the end.
If you guys have any other suggestions I would greatly appreciate the input on this.
Old Feb 21, 2010 | 05:45 PM
SeanW's Avatar
Re: Need cam any suggestions pease!!!
I think thats a good choice of cams. I have an XE268 in a 350 and like it a lot.
Old Feb 21, 2010 | 06:15 PM
radical82's Avatar
Car: '82 Camaro
Engine: 383
Transmission: TKO 5 speed
Axle/Gears: 31 spline 9" with 4.56:1
Comp Cams has a program called Cam Quest that is a free download.... Just input all your engine specs and see what it recomends....
Old Feb 21, 2010 | 06:24 PM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
why the torker manifold?
Old Feb 21, 2010 | 07:40 PM
355sbc's Avatar
Car: 1989 camaro
Engine: 350 sbc
Axle/Gears: 4.10
Thanks for the replys I'll download the cam quest. I got the torker intake cause
it was 50 bucks from my friend
Old Feb 21, 2010 | 08:39 PM
smallblock chevy run best with a lot of plenum volume which the torker lacks. from now on every post i make i will end it with "thats my opinion." some people get way too bent out of shape around here.....thats my opinion
junkcltr
Aug 2, 2019 11:12 PM
transamgta87
Sep 1, 2015 07:07 PM
camaro71633
Sep 1, 2015 10:24 AM
InfinityShade
Aug 22, 2015 08:00 PM
drathaar907
Aug 6, 2015 04:20 PM
