Largest engine?
Car: 89 GTA
Largest engine?
I'm interested in doing a motor swap down the road on my car, but I'm one of those guys that loves sleepers.
Based on the information on the car (in my sig), what would be the largest TPI engine that would fit in my car's engine bay, without altering the stock look of the car from the outside?
1989 GTA: 350 5.7L TPI, 3.5" Y-Pipe, 3" intermediate pipe, Dynomax Super Turbo muffler, twin 3.5" cats, 700R4 transmission, aluminum driveshaft, K&N, 105 Amp Generator, 3.27 gear ratio, axle positraction, limited slip, Dunlop SP Sport 4000 tires (Z-rated, A-traction in all environments).
[This message has been edited by The Dirty Bird! (edited November 10, 2001).]
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Since all SBC engines are the same external size then a 434 is about the biggest you can have without going to some exotic block. An aftermarket TPI needs to be used.
If you want to go BBC then a 540 will fit, again with some aftermarket TPI however a cowl hood may be required.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z SuperPro ET Bracket Race Car
461 naturally aspirated Big Block (times are for the current engine)
Best ET on a time slip: 11.447 altitude corrected to 10.99
Best MPH on a time slip: 119.42 altitude corrected to 124.86
Altitude corrected rear wheel HP: 493
Best 60 foot: 1.586
Racing at 3500 feet elevation with a typical race day over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Best 60 foot: 1.586
if you want a real sleeper put in a 3.8L grand national engine and let them hear the bent 6. Then blow them away
-Tas
'89 Formula WS-6
305, TBI, 700R4, P.A.W. 14x3 open element with K&N, Milodon 160* thermo, functional Formula hood, cross-flow Flowmaster, '99z28 rear pipes and tips, Hooker 1-5/8" 50 state legal headers, Dynomax 3" I pipe (PN 44063 and 43248)
Super GRK_Taz World
F-Body Dual Exaust
EFI & Intake Options
-Tas
'89 Formula WS-6
Super GRK_Taz World
F-Body Dual Exaust
Car: 1988 Firebird, 2000 GTP
Engine: 327
Axle/Gears: 9" posi, 4.11
I think a good ol' Hemi would be nice.
http://www.mopartsracing.com/parts/hemi.html
Has almost everything you'll need. I also have a site for adding Viper engines to non-Viper cars. they sell pretty much everything you will need for teh conversion. I'm not sure though. I don't know exactly what must be done.
http://www.viperconnection.com/parts/crate.html
If only I had $14,000 for a 528 Hemi. What sort of power would one of those put out? I think the 426 was a beast. What would you get with another 100? I think it's around 600hp.
Even though it's not GM, they were still great eninges. It's too bad GM didn't come up with an engine that burns fuel so efficiently.
84z96L31vortec
Aug 20, 2017 12:16 AM
