Confused?????
Confused?????
What should I do? I have a 88 V6 5 speed Camaro and I want to put in a V8 350 but still keep it stick. I was told that that the 5 speed wouldnt be able to hold the 350, so I would have to get a 6 speed. And then even after that, I would still maybe have some problems but since Chevy never made a third gen 6 speed 350 to my knowledge I cant just go buy one. So should I just buy a 93 and up 6 speed V8 or go through everything to making my 88 a 6 speed?
You have a V8 T5 right? Good, then that'll work. If you have a V6 T5, then you would have problems. It should be alright. But see what other people have to say. I
1984 Firebird SE
1985 Camaro z28 305 engine T-5 Five Speed Tranny, 92 Camaro Leather Seats Console, carpet everything. Soon to put in 700R4 and 427CI. (Hopefully.
To view my car go to:
http://geocities.com/jmboriss/bluecar.html
It is for sale, asking $2000.
1984 Firebird SE
<font face="Verdana, Arial" size="2">Originally posted by Bean's Cam:
I was told that that the 5 speed wouldnt be able to hold the 350, so I would have to get a 6 speed.</font>
A 6-speed will swap into an 82-92 f-body fairly easy if you really want one.
So what you are saying is to just stick with the swap of engine and tranny and forget just buyin another car thats 6 speed? I would rather just go the simple route.
Thanks for the advice though.
I have a v6 t5 behind a stock carbed 350. Its holding up fine. As far as I know you can't find a clutch disk larger than 9 1/8 to fit the v6 input shaft. The v8 used a 10.4 in disk. So I have a v6 tranny and clutch behind a 350 and its doing ok. Not sure how long everything is going to hold up but it will get you around for a while. If you can find a v8 t5 cheap get it at least you don't have to be afraid to beat your clutch every now and then.
[This message has been edited by thatsme (edited November 07, 2001).]
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
I currently have a T5 behind a 300HP 350,but I don't plan on it lasting long.....at least not for me.If you like to bang gears or smoke the tires with any regularity, the T5 will not last.If you don't drive it too hard, it will be fine.It all depends on your left foot!My suggestion is to go ahead and run the T5 you have, and upgrade later if you feel the need.If you break it, I wouldn't waste any money on beefing it up,just replace it with a trans rated for more torque.
As for me, I'll be replacing mine in the Spring with a Tremec TKO,rated at 550 ft/lbs!
-Rich-
-Rich-
<font face="Verdana, Arial" size="2">Originally posted by RICH92RS350:
If you don't drive it too hard, it will be fine.It all depends on your left foot!-Rich-</font>
Car: 91 Camaro RS Convertible
Engine: 385ci LT1 cnc ported heads big cam
Transmission: 4L60E automatic
Axle/Gears: 3.42 Zexel posi 7.5" rear
Since your car is a v6 why not just swap the LT1 and 6 speed out of a 4th gen.
Car: 92 Camaro RS
<font face="Verdana, Arial" size="2">Originally posted by Cosmik Debris:
We drive on the other side of the road from some of you guys but we don't use our other foot!</font>
BTW, I like your user name....Frank Z fan?
-Rich-
Car: 91 Firebird
If you have the money, try doing the swap. You could always just buy a LT-1 fourth gen, but what fun would that be? Everyone's got one, how many people have a LT-1 powered, 6-speed third gen? I would find that to be much cooler the the prior. But that is just my opinion, I like uniqeness!
Car: 84 Z28
Engine: L69: cam and porting
Transmission: T5, 3.73 rear
Cosmic Debris...
What is the name of the beach on the very tip of the North Island that you can drive on? I went there like 5 years ago and it was awesome, i just can't remember the name.
I was referring to the clutch pedal.
-Rich-
-Rich-
bubbaz28
Sep 18, 2015 02:09 PM
Denricci22
Sep 18, 2015 09:02 AM
