454 anyone?
Old Feb 25, 2010 | 02:45 PM
90t/aguy's Avatar
Car: 1990 Trans Am
454 anyone?
hey guys, did some thinking today and was like hmmmm......a big block would be pretty sweet in my car. post some pics up of the swap and motor so i can get an idea of parts and stuff.
Old Feb 25, 2010 | 03:07 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The sticky on the topic would be a good place to start:
https://www.thirdgen.org/forums/engi...swap-info.html
Old Feb 25, 2010 | 03:23 PM
GICATA's Avatar
Car: '83 WS6 T/A 65,000 miles
Engine: 5.0L vin H stock, 406SBC right now
Axle/Gears: Corp. 3.73
Re: 454 anyone?
It takes some vaseline, but they go in.....
...it ruins the handling as far as I'm concerned, but you didn't ask me about that.
Old Feb 25, 2010 | 03:45 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
Re: 454 anyone?
I abandon my 454 swap in favor of a 6.0, just going to be cheaper in the long run but DAAAMN i am missing out on torque.
Old Feb 25, 2010 | 07:47 PM
Irockz's Avatar
Car: 87 Berlinetta,work in progress
Engine: 468 BB,still in the build process
Transmission: TH350,3500 stall
Axle/Gears: 9" Ford,learning how to live under
Re: 454 anyone?
I'm willing to wager you've not driven one with a BB swap.The vaseline thing is a myth,they have a decent amount of room,although the headers are tight.The handling issue would only be noticable if aggressive driving on twisty roads were the primary purpose of the car.With a set of springs from a TPI car,(the heaviest factory equipped engine),the handling is changed VERY little.
Old Feb 25, 2010 | 08:16 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: 454 anyone?
Well, mine is a little tight but it's not a typical street engine either. With the raised exhaust port heads and larger header tubes, it's very tight but still fits. It fills the engine compartment more than a SBC does, that's for sure.
MustangBeater20
Oct 29, 2022 09:20 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Mongoose462ci
Sep 16, 2015 11:46 PM
Kaweh
Aug 9, 2015 02:54 PM
cRoe4
Aug 7, 2015 08:46 PM
