Old Nov 9, 2001 | 01:49 PM
Mike's 87 T/A's Avatar
I have a 1987 TransAm with a 305 TPI and a 700R4 auto w/ overdrive. The 305 is getting weak after 110k and i need more power for my bird. I want to get a 350. Either rebuilt through Jasper or a 'base' 350 HO from Jeg's. If I drop in a 350, will i need to change the PROM or any of the computers? I want to keep the TPI set up with bigger injectors and throttle body. Is this an easy swap, or will it burn my wallet?
Old Nov 9, 2001 | 02:49 PM
GTA383's Avatar
The swap is pretty easy just time consuming. If you get the rebuilt L98 motor you might need a chip from a 350 car but the rest of the computer and wiring should be fine. Get a 350 knock sensor and you should be good to go. If you get the HO motor from jegs you may need a custom chip. Get the specs from the cam. It may not be computer freindly at all. Also see if it a 1 or 2 pc rear main. A new flexplate isn't that expensive but you will need it if the motor is a 2 pc. Either way you go, I would get a better intake manifold before the TB if you havn't already purchased it. You will probably see better results from the start and it is easier to add a tb later.
Old Nov 14, 2001 | 04:44 PM
Z03Z28's Avatar
Car: 92Z28,98LegacyGT,ZX9R,91 Z28,02 Z71
Engine: 350,307,2.5,900cc,5.0
Transmission: 700r4,4spd auto,700r4,4L80
Axle/Gears: 323,?,323,?,373
You will only need the fuel injectors
from a 350 tpi.The chip is the same.
The MAS will take care of the air fuel
mix.
Frozer!!!
Jan 19, 2024 04:55 PM
camaro11j
Sep 19, 2018 08:49 AM
theshackle
Mar 5, 2017 06:37 PM
sreZ28
Aug 14, 2015 07:48 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
