someone needs to do this!
Old Nov 6, 2001 | 10:33 PM
Tom84L69's Avatar
Car: 84 Z28
Engine: L69: cam and porting
Transmission: T5, 3.73 rear
Someone with cash should buy a new Corvette Z06 motor (LS6) and put it in a third gen with a T56 and a 4.56 gear. These motors absolutely rock and I would love to see one in a third gen.
While you're at it, send the heads off to lingenfelter and put a cam in it!
Old Nov 9, 2001 | 02:23 PM
Omega's Avatar
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
Send me a blank check and i will send you the time slip
Old Nov 9, 2001 | 02:36 PM
firbird's Avatar
why?? with the money you have spent you could have something much better!!
Old Nov 9, 2001 | 03:41 PM
Tom84L69's Avatar
Car: 84 Z28
The advantages of a new and fuel injected engine are great. Reliable cold start up, optimized spark and fuel delivery and excellent drivability at all rpms.
The fact that these motors can easily make 450 hp and act stock is excellent. Try making a reliable and stock sounding 450 horse small block with a carb.
Plus, it would look really cool!
Old Nov 9, 2001 | 08:19 PM
Guest
Guest
Posts: n/a
Nice idea, but...
I wouldnt use the T56, too many problems with the clutch. Besides, autos are better for drag racing.
Why get the LS6? You can easily build up a LS1 and it will be a heck of alot cheaper.
Old Nov 9, 2001 | 09:12 PM
Tas's Avatar
Tas
<font face="Verdana, Arial" size="2">Originally posted by madmax:
Nice idea, but...
</font>
sticks rule. The LS1s with the t56 got their clutch situation fixed. They use z06 clutches now.
-Tas
'89 Formula WS-6
305, TBI, 700R4, P.A.W. 14x3 open element with K&N, Milodon 160* thermo, functional Formula hood, cross-flow Flowmaster, '99z28 rear pipes and tips, Hooker 1-5/8" 50 state legal headers, Dynomax 3" I pipe (PN 44063 and 43248)
Super GRK_Taz World
F-Body Dual Exaust
EFI & Intake Options
Old Nov 10, 2001 | 02:12 AM
Tom84L69's Avatar
Car: 84 Z28
really, the price diff between an LS6 and an LS1 has to be negligible. Plus you have to factor in the better flowing heads on the LS6.
Also, a manual trans is always better, i don't care if it is stronger or what...it's just that much cooler!
Old Nov 10, 2001 | 04:29 AM
lanyabuddy's Avatar
Where can I buy that LS1 engine complete?
Old Nov 10, 2001 | 11:52 AM
Tom84L69's Avatar
Car: 84 Z28
Try a GM Performance parts dealer.
Jim Pace Chevrolet advertises a lot in hot Rod and Car Craft mags. There are other dealers, try a search on yahoo.
Old Nov 10, 2001 | 08:09 PM
Guest
Guest
Posts: n/a
Tas, thats not what I heard...
Anyway, its a POS setup and I personally would not take the chance of the clutch going up in smoke at WOT doing 30MPH.
Old Nov 13, 2001 | 07:14 PM
82 TRANS AM's Avatar
Car: 82 T/A WS7
Engine: Pontiac 400
Transmission: Muncie 4-speed
ZZ430, S/D T-10, Ford nine inch.
F... FI.
For the $4000 or so difference, i'll sit in the car and feather the gas for a few minutes if it's cold.
Kenney
82 Trans Am WS7 notchback
83 Trans Am WS6 T-tops
Painter @ Chevy dealer
GM junkie
Old Nov 13, 2001 | 11:34 PM
Tom84L69's Avatar
Car: 84 Z28
How bout that fuel economy with your T10?
I'd give a lot of credit to someone for trying it rather than the super common small block.
84 Z28 L69. 5 speed with 3.73 posi (broken)Ported heads, intake, 10:1 comp. 230/230 .480 lift cam @.050"
Old Nov 14, 2001 | 07:18 AM
427camaro's Avatar
Car: 05 Nissan Xterra
Engine: 4.0L DOHC
Transmission: 5 Speed Auto w/ OD
I was actually thinking about doing that to mine a couple months ago. Those motors are about $6000.00, and money's an issue with me, especially that much! Then getting it put in, and anything else you run into.
2.8 Liter V6
No Current Mods
Old Nov 14, 2001 | 08:25 PM
Car: 82 T/A WS7
Engine: Pontiac 400
Mine is just a play car. Gas mileage is no concern. The car has always had a four speed so i can't miss an overdrive i've never had.
Actually, i'd like to get a four plus one. The trans that has a fifth gear 1:1.
The new engines are great, but for the $$$$, more power is to be had at a much lower price. I like having no computer, a linkage clutch, and a carb. Just simplicity.
Kenney
GM junkie
Old Nov 16, 2001 | 10:30 AM
DAVECS1's Avatar
Car: 91 GTA
Engine: 377ci
Axle/Gears: QP Ford 9" 3.70s
I was eyeing a ZR1 motor without ecm for 6500, but in the end I built an aluminum block, aluminum head 383GTA with Accel plenum, runners, and intake base. It came out to somewhere around 5000, but I think I am making close to the same power with more options to make more. The LS1 is a sweet motor and I would highly consider it. Those six bolt mains make it excellent for nitrous and positive pressure applications. Not to mention the electronics are freindly when it comes to upgrades. I spent 5000 on a motor and I am constantly burning chips to tweak it! When it is all said and done the bottom line is sanity and money!
Old Nov 16, 2001 | 10:33 AM
DAVECS1's Avatar
Car: 91 GTA
Engine: 377ci
91GTA 5.7liter needs paint, I rebuilt the trans, engine is moded but old
