i put a 350 in my 84 camaro
Old Nov 20, 2001 | 07:54 PM
kid camaro's Avatar
Car: 91 z28
Engine: 305 tpi
i put a 350 in my 84 camaro. and now the heater wont work. this is my first camaro so i dont know much about them. i would also to know if anyone has any ideas on how to fix a leak. my t-tops leak. really bad. any input would be appreciated.
Old Nov 20, 2001 | 08:17 PM
Joshua Leslie's Avatar
the heater wont work...
do u mean the there is no heat from it, or the blower doesent come on?
if the blower isnt coming on, it is proly a missed wire, I had a similar problem.
Check the ground wire that goes to the back of the transmission from inside the engine compatment, its an easy one to miss. It bolts the bellhousing.
Old Nov 20, 2001 | 08:33 PM
kid camaro's Avatar
Car: 91 z28
Engine: 305 tpi
thanks for the info. it is muchly appreciated.
Old Nov 20, 2001 | 09:10 PM
kid camaro's Avatar
Car: 91 z28
Engine: 305 tpi
where would a good place be to re ground it. i dont wanna have to get under there and mess around with the tranny bolts again.i had to do it more then once as it is. thanks again for the help.
Old Nov 20, 2001 | 10:00 PM
U can ground it to anywhere there is metal.
just be sure it is unpainted.
Old Nov 21, 2001 | 12:25 AM
JunkHead84's Avatar
if its not unpainted just sand it.
MustangBeater20
Oct 29, 2022 09:20 PM
camaro11j
Sep 19, 2018 08:49 AM
Mutillator
Exterior Parts for Sale
Jan 2, 2016 06:44 PM
camaro71633
Sep 1, 2015 10:24 AM
Fronzizzle
Aug 9, 2015 01:15 PM
