which motor?
Old Nov 22, 2001 | 09:30 AM
PimpCamaroRS's Avatar
which motor?
i have a 305 tbi in my 91 RS. its just not working for me.i need more power. i would like to buy a short block 350(already with nice cam, pistons,etc..) or a short block 383. i am just wondering which would be easier to find parts for. what kind of heads do you use for a 383, do you just use 350 heads or 400's or what?if you have to do a lot of costum stuff to a 383 i think i would just stick with a 350 so i can just buy the heads and intake i want and drop it on in. which would be easier for a high school kid with not much knowledge about engines?
Old Nov 22, 2001 | 09:45 AM
also what is an adjustable fuel pressure regulator. would i need it for the major add ons i will be doing to my car. if so where could i find one? thanx
Old Nov 22, 2001 | 02:17 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
An AFPR simply means you can turn a screw to change the fuel pressure vs. being pre-set. There's an article in the tech section about converting your factory reg to adjustable.
You might try asking your questions on the TBI board, as those guys will have more insight into making it work with a larger engine.
FWIW, the 350 is a simplier choice. But, you can make your 305 run much better with typical TBI improvements.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4, 2300 stall TC. Ported World 305 heads, Crane PowerMax 2050 cam. ZZ3/4 intake, oil pump, pan & baffle. Accel HEI SuperCoil & module. Hooker 2055 headers, 3" Catco cat & 3" catback w/dual-opposite Flowmaster 80. 2.93 limited slip. Spohn SFCs waiting to be installed. AMSOIL syn lubes bumper-to-bumper. Daily year-round driver. Best ET, speed TBD...
57 Bel Air, my 1st car. '66 396, 9.7:1 forged TRWs, Weiand Action+, Holley 750VS w/4150 conversion, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 700 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
Old Nov 22, 2001 | 07:58 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
Pimp, I notice you live in California. Are you subject to emission testing? If so, your first mod will be to move to another state that doesn't have emission testing.
As I understand California's emission laws, you can't just replace your motor with a bigger motor. You engine swap will need "approval". Also, every part installed in Californa MUST have a CARB#. No Miniram, no 383, no swapping on a carburetor, no removing your catalytic convertor, ... basically, no fun.
I don't live in California and I am by no means an expert on California's emission laws. I am only going by my faded old memory from chatting with my friends that live in California.
Review your emission laws first, and then you can determine what you can do and cannot do. Your engine build up is more limited than in states where you can pollute good like a car should.
Old Nov 22, 2001 | 09:10 PM
well what i was thinkin what a rebuilt 350,with a desent cam, super Ram, holley 670 TBI, Fast Burn Heads, and some good hooker header or SLP's. i could really give a F*** what CA thinks about my car but as long as it passes the sniffer i am good. so you guys think my combo would work?
Old Nov 22, 2001 | 09:16 PM
Car: Death Mobile
Engine: 666 c.i.
I would scope out the TBI Board to see what you can do with your TBI. As for your chip (yup, you'll need one of those), scope out the DIY Prom Burning Board and look at learning how to burn your own. The stock eprom will not work.
As for emissions, well I can sympathize with you. The Smog ***** make it difficult. But you should ask about the Emission Laws on the Tech/General Board. It would be a crying shame to spend thousands of dollars and then being told your car is illegal.
[This message has been edited by Glenn91L98GTA (edited November 22, 2001).]
Old Nov 22, 2001 | 09:53 PM
firbird's Avatar
well i would have to say that the 350 will be so much easyer for you, you can go with the holley 670 tbi unit, its injectors are peices of crap and should not be allowed. the 670 unit will just plug in with some slight modifications,the fast burn heads i have heard bad things about them and that they are over priced and the vortecs are better than them intill high rpms. if i was you i would go with a crate engine if its your first time, . you could go with what i did and just get a 330 hp gm crate engine that is fairly cheep but it all adds up but its more than decent
Old Nov 22, 2001 | 10:58 PM
i am pretty much looking for 350+HP in the cheapest way. what about a 350 with the holley 670 TBI, holley intake which fits perfect with TBI, then some AFR heads. what u think about that combo?
Old Nov 23, 2001 | 09:41 AM
come on guys i know some of you guys have over 350 horses.how could i achieve that with a 350.
hydrolic144
Sep 8, 2015 06:55 PM
masonta
Sep 1, 2015 06:40 PM
greenyone
Aug 29, 2015 11:08 AM
Randomtask2
Aug 26, 2015 03:34 PM
slade5612
Aug 11, 2015 07:19 PM
