can I change the cam without pulling the motor?
Old Nov 17, 2001 | 09:56 PM
Joshua Leslie's Avatar
hey
I got an 89T/A
Old Nov 17, 2001 | 10:07 PM
Tas's Avatar
Tas
yup
-Tas
'89 Formula WS-6
305, TBI, 700R4, P.A.W. 14x3 open element with K&N, Milodon 160* thermo, functional Formula hood, cross-flow Flowmaster, '99z28 rear pipes and tips, Hooker 1-5/8" 50 state legal headers, Dynomax 3" I pipe (PN 44063 and 43248)
Super GRK_Taz World
F-Body Dual Exaust
EFI & Intake Options
Old Nov 17, 2001 | 10:45 PM
how?
Old Nov 17, 2001 | 11:00 PM
Guest
Guest
Posts: n/a
I wont cover everything here:
Loosening up the oil pan would be a good start, then you can get the timing cover off (once all the accessories are out of the way of course). The radiator has to come out, and the AC condensor (if you have AC) can be moved up enough for the cam to clear. There are 2 cross braces and theres a brace under the hood latch that needs to be removed as well. Once you get all that out of the way, the cam can be taken all the way out of the block.
If you are looking for a detailed step by step, try the tech articles. If theres nothing there and you need more information, a manual would be a good idea.
Old Nov 19, 2001 | 11:37 AM
RICH92RS350's Avatar
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
The intake manifold & valve covers gotta come off too,though these are easy.It takes some time to do it with the motor in the car,but it's mostly all the disassembly required to get to it.The first three cam installs I did, were all with the motor in the car.Buy all the gaskets & stuff ahead of time and give yourself a weekend to do it if you don't have help from somebody with experience.
-Rich-
Old Nov 26, 2001 | 10:53 AM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.54 Dana 44 IRS
you have to jack the motor up to get teh oil pan off right?
86 IROC
43,000 miles
305/700R4/3.23 gears
maroon, gold stickers, black interior, T-Tops.
current mods.
shift kit
headers
cat back exhaust
mods planned for this winter
cam
Adjustable fuel pressure regulator
port and polish intake and heads
lookin to run low 14s maybe squeak out a 13.9 with my stock chip
Old Nov 26, 2001 | 12:23 PM
afgun's Avatar
Car: Non F-body :(
Engine: Pontiac 301
Transmission: TH350
To remove the oil pan, yes you need to jack up the motor considerably. If you're only trying to loosen the pan to get the timing cover off I don't think you need to raise the motor.
Old Nov 26, 2001 | 12:42 PM
Car: 92 Camaro RS
Yeah, you shouldn't have to move the motor any to loosen up the pan.You just need to loosen it up enough to drop the front of the pan 1/4" or so, so you can wiggle the timing cover out.
-Rich-
eightsixseven
Dec 16, 2024 01:50 PM
Frozer!!!
Jan 19, 2024 04:55 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
cstrobel65
Aug 15, 2015 10:19 AM
anesthes
Aug 8, 2015 09:37 PM
