Motor Swap
Old Nov 26, 2001 | 11:46 AM
DaveK's Avatar
Motor Swap
Just installed a 350, .030 over, decked and balanced. Put the TPI stuff on it as well. Installed a set of edelbrock headers. Now, for my problem. I still have the stock injectors and fuel pressure regulator. Timing is set at 0 deg according to the sticker on the hood. Engine appears to be running hot at higher rpm's. the temp comes down when the engine is idling. I had to use adapters for the sending units because the heads areolder style. this brings the sending unit out toward the header... could this be why it appears to be running hot? i have new thermo, radiator and water pump. very good curculation it appears. only 1 stock electrical fan.
Please help
Old Nov 26, 2001 | 12:21 PM
afgun's Avatar
Car: Non F-body :(
Engine: Pontiac 301
Transmission: TH350
Stock timing for TBI is 0 degrees; stock timing for TPI is 6 degrees BTDC. Retarded timing could be contributing to your heating problem. Warm it up, disconnect the EST wire and then set your timing.
Old Nov 27, 2001 | 05:54 AM
DaveK's Avatar
OK I set the timing to 6 deg BTDC. Seemed to help a bit but the temp still creeps up with engine speed.
By any chance, do any of the ports in the intake gaskets need those blocker plates installed?
I also put the AFPR on yesterday and set the pressure to 47 psi.
BlackphantomZ28
LSX and LTX Parts
Oct 19, 2015 06:25 PM
E Rod
Aug 28, 2015 05:17 AM
355sbcTPI
Aug 19, 2015 04:38 PM
86White_T/A305
Aug 17, 2015 12:16 AM
st.evel07
Aug 13, 2015 06:15 PM
