305 help
Old Nov 14, 2001 | 09:23 PM
montesa311's Avatar
Car: 83-84 camaro, 95 formula firehawk
Engine: 305, 305ho, 350tpi, 350 lt1, 383lt1
Transmission: 700r4, t-5, t56, m6
Axle/Gears: 3:90, 4:10, 3:50, and more
305 help
i own a 83 z28. I live in colorado springs, colorado. I am intrested in "retiring" the tired 305 4bbl. I have a 700r4 so the 305 is not the ho.
to the question. What is a good swap, what about emmisions, where can i get info on emmisions for colorado, i would also like to keep gas millage semi good. But the only requirement is that I have to beat my dads 86 vette!!!!!
women and project cars are two things guys can't live with out, too bad women and project cars dont get along!!
Old Nov 14, 2001 | 09:36 PM
firbird's Avatar
welcome
i wanna be the first to say if you want cheep hp get a 350 and if you are looking for mpg i would think about fuel injection i dont know if are on a tight budget or not but if you want preformance and mpg i would go to fuel injection, you can get a tpi set up for about 500 bucks if you search a little and are you planning to build the new engine or just buy the complete engine? it sould not be that hard to beat the corvette if you get good traction and a decent engine.
Old Nov 14, 2001 | 09:58 PM
montesa311's Avatar
really i would be looking at building the engine in my shop over a wile because i am on a tight buget! Walliworld (walmart)
I have all the stands, tools, and so on, but have been all over the junk yards here and have looked for tpi's and there hot itmes here there gone befor the car is there a day. i was thinking a tpi unit on a 350. I would rather build a motor then swap with the one in my car, so im not out of a car for too long.
Old Nov 17, 2001 | 09:20 PM
montesa311's Avatar
what about emmisions comtrol, i live in colorado springs and i guess i first need to know what legally i can do and what motors i can put in this. does any one know where i can find info on this?
Old Nov 20, 2001 | 12:46 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
There are two things to keep in mind when swapping with emissions looking over your shoulder:
1) Keep it "looking" legal, to pass the visual inspection. Generally, that means keeping everything on that it originally had (or if updating to a TPI, what a TPI car had)such as the smog pump, air cleaner, EGR valve, catalytic converter, charcoal canister, and even the SES light (to prove the computer is working), and everything associated with making those things work. When they do the visual inspection, they have a list, plus are supposed to be able to look at the underhood stickers, for what it should have. That also means you don't put a 454 under the hood. You can, however, use certified replacement parts such as headers.
2) Keep it "sniffer" clean, so that you don't put out so much of the bad compounds that you fail that portion of the test. That means don't gut the cat, put in a cam with too much duration and overlap, etc.
Although I haven't had it checked yet (passed emissions just before taking it apart), the modifications in my sig are technically all legal. I could have done similar things to a 350 or 383, and as long as I could tell them (if they asked) "Yep, it's a 305" with a straight face, either of those engines would also be "legal".
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4, 2300 stall TC. Ported World 305 heads, Crane PowerMax 2050 cam. ZZ4 intake, oil pump, pan & baffle. Accel HEI SuperCoil & module. Hooker 2055 headers, 3" Catco cat & 3" catback w/dual-opposite Flowmaster 80. 2.93 limited slip. Spohn SFCs waiting to be installed. AMSOIL syn lubes bumper-to-bumper. Daily year-round driver. Best ET, speed TBD...
57 Bel Air, my 1st car. '66 396, 9.7:1 forged TRWs, Weiand Action+, Holley 750VS w/4150 conversion, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 700 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
Old Nov 27, 2001 | 03:13 PM
bigals87z28's Avatar
Car: Check The Sig
hey
i have a 305 tpi engine. i now know that the tpi will fit a 350. can someone tell me if a crate engine with its manfold taken off and addapted to the tpi will work. i want a 350 in my baby. here is not a ton to work with out there with a 305 thank u
pjsparts
Oct 29, 2025 06:39 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
rsrookie
Sep 5, 2015 07:08 PM
Formula_88AE
Sep 3, 2015 01:47 PM
