need bbc 427
Old Dec 1, 2001 | 02:21 AM
redneckmilita@aol.com's Avatar
need bbc 427
I have desided to build a n/a 427 powered camaro. What should i get the motor from. I am going to use after market heads and pistons but would lik to find a block that came with a forged crank.
Old Dec 1, 2001 | 06:05 AM
ede's Avatar
ede
i think any 427 from a car would be forged, maybe the trucks too, but i'm sure you don't want one from a truck. why 427 when 454s are so much easier to find? i'd look at the car shows and swap meets for one short of buying a new block or engine.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Dec 20, 2001 | 03:55 PM
9.0L Firebird's Avatar
The easist way to go is to get a late 70s early 80s 454 truck motor
a good running 454 core is less than $1,000. put a good set of oval port heads on it (781s, 049s or 292s) with a decent size cam in it and you are near 500hp for less than $2,000. BTW most 427s came with steel cranks. Be very careful that you do not buy a 427 heavy truck motor these are tall deck blocks and are NOT what you are looking for. the deck height on a std BBC is 9.8", truck (tall) decks are 10.2".
Old Dec 21, 2001 | 04:09 PM
PETE's Avatar
Car: 1989 TTA #1240
Engine: 3.8 SFI turbo
Transmission: 2004r
you may want to check gm i agree on the 454 they evenn may sell a partial 454(minus cam,heads,pan,etc.)from the old ss trucks.if cost isn't a problem thhe zl1 is reproduced with gen v enhancements.
Old Dec 21, 2001 | 09:54 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Unless you have some design criteria for why you need a 427 you might as well use a 454. It's just like the small block guys going with a 327.... why? All small blocks look the same. You might as well do a 383+ and make more power. People can't tell what you've got. Same thing applies to big blocks. Do what makes sense... not what sounds like a cool thing. All that matters is how fast you can go. People don't care what you've got (unless they lose ).
Loudnproud86
Jul 14, 2016 12:59 AM
92rsvortec350
19
Oct 9, 2015 09:39 AM
vortec tpi
Sep 26, 2015 08:14 AM
vortec tpi
Pacific Northwest Region
Sep 26, 2015 08:13 AM
Tylermcclinton
Sep 17, 2015 07:50 PM
