What effect does removing a smog pump and all accessories from a 305 tpi have?
Old Nov 29, 2001 | 02:20 AM
digimagix's Avatar
I have an 88 Trans Am all stock, i want to remove the smog sh*t including all the air tubes, hoses, pump, and the little black box with two wire connectors leading to it, i am thrown off and dont know what effect this will have and if it is computer controlled or not. someone plese help. email me or post here, thanks alot.
Erik
Old Nov 29, 2001 | 02:48 PM
a73camaro's Avatar
Difficult to resell with missing smog equipment.
You won't feel a "seat of the pants" improvement.
Up to $50,000 and/or up to 6 months in jail if caught.
More tailpipe emmission with smog gear removed.
Leave it on there.
Old Nov 30, 2001 | 08:39 AM
Z28 Boy's Avatar
Car: 1991 Camaro RS
Engine: GMPP 350 HO w/TBI
Transmission: 700R-4
Axle/Gears: 10-bolt w/3.73s
well i disagree with the previous post about leaving it on. i think it should go peronally.
i hated it when i had it, and since i took it off and got smoothe headers with no air tubes, the engine compartment has looked about 50 times better.
i really dont think that you will feel anything. i didnt. its not enough of a restriction to make any power. if you do it do it ONLY for an appearance/cleanliness mod, NOT a performance mod, or you will be upset.
just my 2 cents.
-brian
1991 Camaro RS
GMPP 350 HO crate engine - Holley TB, MSD ignition, SLP exhaust, everything is new
700R4 - 2,400 stall converter, vette servo, shift kit
My car's webpage - z28boy.cz28.com
President - Central New York F-Body Association
Email - z28boy@twcny.rr.com
AIM - "Z28 Boy"
Old Nov 30, 2001 | 06:01 PM
Chevy83Z28's Avatar
I took my air pump equipment off only because the exhaust manifold tube had a huge hole in it, resulting in an annoying exhaust leak. Between taking the smog stuff and a/c compressor off, it's really cleaned up the engine compartment. You can actually SEE the block now! But as Z28 boy stated, it's not gonna make such a huge performance difference unless your equipment isn't working properly.
But the "black box" that you describe, I'm not sure what you're talking about, but if it's the charcoal canister that has vacuum lines coming out of it, don't take that out. I did that on my old car and it made the car stink of gas when it runs (it filters out gas fumes.) (On my 83 Z28, its located right behind the left headlight assembly by the horn.) Maybe try to clean it or something if you're that worried, but I honestly wouldn't take it out.
[This message has been edited by Chevy83Z28 (edited November 30, 2001).]
Old Dec 1, 2001 | 11:58 AM
BLACK Z's Avatar
Car: 86 Z28
Transmission: W/C T-5
Axle/Gears: 9 BOLT 3.45 POSI
Moved to tech section.
86Z28, GM 350, Jet perf Q-jet & chip Dual snorkel air cleaner, Edelbrock performer intake, Edelbrock headers, Edelbrock cat-back, Off road pipe, MSD 6AL, Accel Super Coil, Taylor Spiro-pro wires, Rapid fire plugs, Jet fan switch, World class t-5, Hurst Short Throw Shifter, Ram Flywheel, Center force dual friction clutch,Aluminum drive shaft, BW disc rear 3.45's & a posi, PBR calipers, Earls braided brake lines, Polygrapite bushings all the way around, poly tranny mount & torque arm mount, Hotchkis lower control arms & panhard rod, Rancho limiter straps, KYB struts & shocks, Gm Wonderbar, Edelbrock strut tower brace, SSM sub frame connectors, Jamex lowering springs, Carbon metallic brake pads, Crossed drilled rotors, Mobil 1 Tranny fluid & motor oil, GM syntheic rear end oil, K&N, Grant stering wheel, 1,200 watt system, Jet Black Paint, 91 Z28 rims, 92 wing, Tinted windows.
BlueIroc-Z
Jun 9, 2019 03:22 AM
italiano67
Dec 11, 2016 09:21 AM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
