I want to be in the low 11's with a sb
Old Nov 7, 2001 | 12:04 AM
THREAT's Avatar
Ok here's the deal I want your opinions on what I should do. I have a 86 Trans AM with no motor or tranny. I am on a budget of about $7000. I want to hit low 11's maybe high 10's by next summer. This should be possible on a supercharged small block right? Keep in mind this car is a 2nd car only to be driven on the weekends and maybe on a nice day here or there. With my budget of 7g's and I will be doin all the work myself. I just got a job today interning at a machine shop so that opens up my possiblites even more. So what should I put in the small block to hit my goal. Lemme ask you guys this if you were to build an 11 sec third gen how would you?
92 honda civic
w/95 gsr a hell of a lot of bolt ons and a 75hp shot
86 Trans Am (in progress) w/383 stroker
turbo 400 thats it so far shooting for 10's
Old Nov 7, 2001 | 02:54 AM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
You'll need around 650 700 hp.
Old Nov 7, 2001 | 04:13 AM
Tas's Avatar
Tas
400 racing block $1500, AFR heads $1500, Multi Port intjection $1500, Nos $500 , $1000 crank, Rods and pistons $????, $1500 t56
or Tubro 3.8L with auto.
-Tas
'89 Formula WS-6
305, TBI, 700R4, P.A.W. 14x3 open element with K&N, Milodon 160* thermo, functional Formula hood, cross-flow Flowmaster, '99z28 rear pipes and tips, Hooker 1-5/8" 50 state legal headers, Dynomax 3" I pipe (PN 44063 and 43248)
Super GRK_Taz World
F-Body Dual Exaust
EFI & Intake Options
Old Nov 7, 2001 | 09:33 AM
85transamtpi's Avatar
If you want to use a small block, I have to agree with the previous post. I say 400, forged everything, a serious cam, aluminum heads w/ a lot of compression, solid lifters, a big carb/intake, and lots of nitrous . I dont think 7g's is enough cash to go with a turbo setup, a blower could be an option, but nitrous is just cheaper. Keep in mind that for every dollar you spend on making power (engine), you should spend one getting the power to the ground. I'd say you can build a serious 10 bolt w/ 4.xx gears (or get a 12 bolt), build a 700r4 to **** or get a t400 or t350, get some serious tires, some junkyard front shocks and you should be ready to hook it up. I would look around at people here that run low 11's and see how they are set up. Its okay to "copy" a setup that has worked well on other thirdgens.
Old Nov 7, 2001 | 01:15 PM
Fastcamaro87's Avatar
check out the latest issue of GM HIGH TECH PERFORMANCE there is a black formula in there running a vortech supercharger, 406 motown block, cola crank, Mini-ram 55lb injectors full manual turbo 400 and a bunch of other stuff, it runs 10 flat at 140 mph , if i were you i would look into that
87 IROC-z 305 TPI
Borg Warner T-5 fresh rebuild
10-bolt 3.73 Richmond gears rebuilt GM posi,
formerly BW 9-bolt w/3.45 gears(broke it)
Ported Plenum and Runners Homemade AFPR
ACCEL 8.8 wires, High output coil,and cap & rotor
Bosch platinum + 4 plugs
Ram Air w/ K&N filters,
MAF sensor screens removed, TB coolant bypass
Polyurethane tranny and torque arm mounts
Dynomax catback w/custom tips
K&N oil filter,Mobil 1 synth,Factory Oil Cooler, Futura GLS Super Sport tires 265/50/15 rear and 235/60/15 front mounted on 86 monte carlo SS rims ,
400 sbc and a 6 spd in the works
Old Nov 7, 2001 | 04:08 PM
SoCo80p's Avatar
its really not all that hard to do, just get a 350, get a steel crank (250$) H-beam rods (500$) some good forged pistons ($400) machine work figure around 6-700$, headers (150$) exhaust (300$) built TCI 700R4 (1,200$) auburn posi and strange axles (700$) 10" converter (400$) intake and carb (400$) nice solid lifter cam and roller rockers (300$) and a NOS cheater system (150-250 HP shot) thats about 475$ so the cost here is a hair over 5K factor in some frame ties, good tires and other misc. things at will put you in the 6K range and ever a little gas money in your pocket and some $$ to get the bottle filled a few times
Old Nov 7, 2001 | 05:43 PM
johnsjj2's Avatar
Car: 1991 Z-28
Transmission: T-5 (gonna buy the farm)
If it would hook, 650-700hp would put him in the high 9's. 500-600 is needed for 10-11's.
Joshua Johnston
1991 Z-28
350, T-5, K&N, Ported Vortec heads, Edelbrock RPM, Holley 750 D.P., HEI, 11.07:1 CR, Comp Cams Roller-.510"/.520"-282*/288* dur., Shorty Headers, Dual 2.5 Exhaust, Dynomax Bullet Mufflers, T&R Motorsports custom air intake, Bald tires
Old Nov 7, 2001 | 10:30 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
If you're going to be pushing 500-600 hp you'll need a bit of suspension work. Stock suspension won't let you hook up that much power to the ground. Add in that extra cost too.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z SuperPro ET Bracket Race Car
461 naturally aspirated Big Block (times are for the current engine)
Best ET on a time slip: 11.447 altitude corrected to 10.99
Best MPH on a time slip: 119.42 altitude corrected to 124.86
Altitude corrected rear wheel HP: 493
Best 60 foot: 1.586
Racing at 3500 feet elevation with a typical race day over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Old Nov 8, 2001 | 12:57 AM
vortecfcar's Avatar
Car: '98 Z
Engine: LS1/6
Transmission: 4l60E
yeah Ill second stephen, I have an eleven second car...I just cant get it to hook hard enough. A decent 350 on NOS or ATI/vortech hooked to a serious suspension will put you deep into the elevens
91 RS W/carbed 350, Vortec heads, performer rpm, Comp cams Xtreme energy 224/230 duration and .477/.480 lift. BFG Drag radials. 3.42 posi,Corvette servoed 700r4, 3000rpm stall converter. Edelbrock TES, 3inch cat, flowmaster with single 2.5 inch exit.
Best time yet to come
13.0 @ 107- N/A
12.5@ 117- 100HP Nitrous
This is a Pic of my car in race trim www.tbns.net/billyjay/camero.jpg
Yes I know how to spell camaro- so dont ask. I didnt make the link
Old Nov 8, 2001 | 02:02 AM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Think of the car as a whole and not just the engine. You should count on doubling your budget.
Old Nov 8, 2001 | 11:00 AM
zerogauge's Avatar
remember also that it takes less hp to push a lighter car into the 11's. remove everything and anything you dont need/use. like heavy stereo equipment, could convert power windows to manual remove ac system if its feasible where your located. loose the spare and jack(lose your ability to repair a flat though) im sure people can come up with other stuff to take out....just a suggestion
Old Nov 8, 2001 | 04:17 PM
johnsjj2's Avatar
Car: 1991 Z-28
Well guys, I must renig on my previous post of 650-700 for 9's, and 500-600 for 10-11's. There are a lot of variables that need to be taken into account before I say something like that. I should have said I have seen 11's done with 550hp. But I also just read an article of a guy in a Regal with a TT 355 on 19psi boost, making a little over 950hp, and he is running 9.04et/154mph. zerogauge made a good point, the lighter the car is, the easier it will be to propel into the 11's.
Joshua Johnston
1991 Z-28
Old Nov 8, 2001 | 05:39 PM
F-BIRD'88's Avatar
Thats why I suggested 650 to 700 hp 'cause he can do that on a close to stock chassis
and hit his goal.
[This message has been edited by F-BIRD'88 (edited November 08, 2001).]
Old Nov 8, 2001 | 06:28 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Heavy cars are also harder on parts. My car race ready with me in it is still over 3200 pounds. If I could get it down to 2800 I should be very low 11's if not 10's.
Old Nov 8, 2001 | 06:50 PM
92formula's Avatar
Car: 1992 formula WS6
Engine: none
Where can you get a 400 racing block for $1500?
Old Nov 9, 2001 | 05:22 PM
bzznczzn's Avatar
Poeple hit elevens with 400rhp. Suspension is a major player in this. Get some Dr's, a big stall, lca's, drag shocks and you'll suprise yourself with how fast a base TPI350 can run. If you can lay down 400rhp with this set up, you can easily attain 11's.
Old Nov 11, 2001 | 08:17 PM
Rokshocka's Avatar
lose your back seats... thatll lower u like 1 tenth lol
Old Dec 1, 2001 | 08:49 PM
grendal's Avatar
People have run 10's in 450hp LS1's and 11's with 400hp LS1's... don't need no 600hp.
-Michael
1998 Chevrolet K1500 ext. cab
-Z71 Off-Road package
-350 Vortec
-American Racing Atlas 16x8's
-33" tires
Recently traded:
2000 Chevrolet Camaro Z28 6-speed
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
bjpotter
Oct 4, 2015 07:48 PM
gord327
Oct 3, 2015 01:25 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
Giocio
Oct 1, 2015 12:20 PM
