Sportsman II 72cc heads
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
I am unsure if i should buy the 64cc or the 72cc heads. The pistons will be stock 4 valve relief. The stock L98 are 64cc i think that will give me a 9.4 CR correct? If i went with the 72cc the CR would drop down to 8 CR or so right? This engine will be NA. I want to run pump gas.
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
Go with the 64cc heads.At 9:4.1 you will still be able to run pump fuel.The 72cc heads would drop your CR and kill some power,and being as you are running NA all the compression you can keep will help.
1982 Z28:355,4 Speed,Lots of bolt ons
Engine: LS1 / LS3
Thats what i thought it would be. Looks like the heads will be a pass. If anyone is interested there are a set of 72cc's on ebay for $260.
Hotrodboba400
Dec 10, 2019 07:07 PM
92projectcamaro
Jan 18, 2016 08:00 AM
